It is currently Sat Nov 14, 2026 4:52 am
Post Posted: Sat Dec 17, 2011 10:07 am
Is the alternator wiring on a g16a the same as a g13b?? My car has died and I need to get it fixed tonight help me please
Post Posted: Sat Dec 17, 2011 5:10 pm
There should be a two pin plug on both. If the actual plugs are different just lop the 1.3 on off and splice in the 1.6 one. One wire is a sense wire and the other one does something else. It's easy to tell if ya got it the right way cause if it's wrong the battery light won't come on in the dash when ignition on. If it doesn't light up try the wires around the other way.
Post Posted: Sat Dec 17, 2011 10:02 pm
Ohk thanks for that I'm thinking the alt is shagged but I'm not to sure
Post Posted: Sun Dec 18, 2011 12:01 am
What's it doing?
Post Posted: Sun Dec 18, 2011 1:11 am
When it's runs it's like the alt is draining the battery insted of charging I'm thinking could the wires be back to front?? Bad battery and needs a charge it looks pretty new when stuff contains wire or power I'm shit with it. It was sitting for a couple weeks when I got and the starter needed a reco so I'm thinking same with the alternator
Post Posted: Sun Dec 18, 2011 1:14 am
It'll cost ya 20$ to get a auto sparky to bench test it. Have you tried the wires around the other way? What's the dash lights do when you pull the plug out and turn the ignition on? An what does it do with the plug in it?
Post Posted: Sun Dec 18, 2011 3:59 am
I haven't tried round the other way I'll do it once I'm home but I might just get it recod saves alot of craping around see how I go thanks for the help bud
Post Posted: Sun Dec 18, 2011 5:59 am
I tired it with the vitara plug and no battery light is showing rather way I wire it up could it be the wires for starter and alt are wrong way?
Vehicle: SWB sj70
Post Posted: Sun Dec 18, 2011 8:54 am
1 wire will be your power feed and the other wire will be your warning light, to find which is your warning light grab your test light and earth it out so clamp onto bolt, body or negative battery terminal and plug the other end into the plug on one connector and then turn your ignition on, this will complete your circuit and then your other connector will be power :)
Post Posted: Sun Dec 18, 2011 9:47 am
How do you mean starter and alt wrong way? I run a feed from
Battery to starter and a feed from battery to alternator for the charge wire. It shouldn't matter. The battery light needs to show up on the dash and go out once ya car is running. Try to swap the wires round. If it still does t work take it to be bench tested.
Post Posted: Sun Dec 18, 2011 10:59 am
I'm taking it to get tested tomorrow makes it easier buy on the Sierra my alt is wire is a white with yellow strip that goes from pos to back of alt and at the terminal it's got a clip and when I disconnect it engine dies dos this sound right?
Users browsing this forum: No registered users and 84 guests
