It is currently Sat Oct 24, 2026 3:17 pm
Post Posted: Wed Dec 14, 2011 8:28 am
There's a lot about tyres I don't undertand,
I've got shitloads,..235/75R15'
They're foot print is different..185 to 200.wide.?
How is this so ?
bye
Post Posted: Wed Dec 14, 2011 9:50 am
How is this so ?
bye
Tyre's blow goat's......
235 is 235mm, that's metric
the profile Ie..... 235/75/ what ever is a percentage of the width :?
Now the good bit!!! :P
14, 13, 17, 12, 18, 24..... :? inch's..... :roll:
Oh, what was the question???
Post Posted: Wed Dec 14, 2011 10:00 am
and to convert them to imperial i use this website
http://www.onlineconversion.com/tire_si ... ersion.htm
235/75/r15 = 28.9"
Is it random, unclear question night tonite?
Post Posted: Wed Dec 14, 2011 10:04 am
why?? :?
Is that normal??? :?
Craig..... 8O
Vehicle: '94 suzuki maruti
Post Posted: Wed Dec 14, 2011 11:31 am
235/75R15...
235=235mm wide
75 is the 'profile', or height, of the tyre measured as a percentage of the width... meaning 235mmx75%= ~175mm. you double this because the 'profile' is between the rim and the surface contact area. so 350mm is the total height of the rubber part of the tyre
R15 is the rim size in inches
to get total size of tyre, add rim & rubber heights together. 350mm = ~14".
so your tyre size is ~29". (this is with a bit of rounding off, actual figure collected from atari's link, as he stated, is 28.9")...
hope that helps... :helloo:
Edit: because my description is so good :crazy: i did a little bit of noobcad on a google image:
Post Posted: Wed Dec 14, 2011 12:16 pm
as for why ones 185 wide and ones 200 wide on the ground, check your pressures, and don't compare front and rear, cos the fronts got more weight on it. (well, actually it means you might want to lower or raise the pressure on one or the other to balance it out).
Post Posted: Wed Dec 14, 2011 5:23 pm
The tyres have the same pressure, are all marked 235/75R15,the trailer spare is 15mm wider than the car spare across the tread
Post Posted: Wed Dec 14, 2011 6:13 pm
it depends on lots of things like carcuss construction and how the tread base is designed.
some LT tyres have a massively narrower foot print than the actual carcuss width.
just run two tyres of the same brand like you should anyway and its all good
bye
Post Posted: Wed Dec 14, 2011 9:30 pm
as i said, different weights front and rear means the front tyre will bag more on the road giving a wider footprint than the rear.
Post Posted: Wed Dec 14, 2011 9:52 pm
Different brands make different size tyres. Even though they are the same marked size..
Measure a 35" BFG to a 35" Nankang. The Nankang will be smaller ;)
hi
Post Posted: Wed Dec 14, 2011 11:19 pm
You might find there is some diffenence between rim widths as well (trailer and car) which can affect the tyre width (and diameter) too.
Post Posted: Thu Dec 15, 2011 6:11 am
How is this so ?
bye
The tyres will be 235mm from the side wall bulge to the other sidewall bulge. The width of the "footprint" will be less than that
My Grand Vitara
Users browsing this forum: No registered users and 87 guests
