It is currently Wed Sep 30, 2026 11:49 am
Post Posted: Tue Sep 02, 2008 9:57 pm
can any one help me out with my transfer case i have a set of stage 3 reduction gears to put in but need to replace the needle rollers an bearings on box, thrust washers and replace all ceals where can i go besides suzuki sports for my needs ? cheers.
Post Posted: Tue Sep 02, 2008 10:16 pm
Check your counter shaft, it'll probably need replacing too.
Post Posted: Wed Sep 03, 2008 12:51 am
by the sounds of that i best just re build it cheers.
Post Posted: Wed Sep 03, 2008 2:45 am
If you are putting some $$$ gears into it then it's a good idea.
Post Posted: Wed Sep 03, 2008 11:15 am
http://www.locktup4x4.com.au/ in Australia
http://www.lowrangeoffroad.com/ in the States
Post Posted: Wed Sep 03, 2008 9:04 pm
i checked out locktup an the transfer case re build kit doesnt show the needle rollers only the ball bearing type, i have needle rollers in mine?
Post Posted: Wed Sep 03, 2008 10:21 pm
cbc, bsc etc.... any bearing shop will be able to supply you with what you need
I rebuild mine recently and made note of the part numbers
these are BSC part numbers but most places should be able to workout what you need.
62/28C3 ball bearing x3
63/22C3 ball bearing x1
6306NRC3 ball bearing x1
TC12545 oil seal x2
TC12539 oil seal x1 (this seal may be different if you have a case without the handbrake attached to it, I can confirm in a few weeks)
this doesn't include the needle roller bearings but the bearing shops should be able to supply them if you give them a sample.
this all cost $113.90 trade price. well worth it when you consider the cost of the gears they are supporting. oh yeah, dont forget to set the shaft endfloat/bearing preload when you rebuild the case.
I got the case gaskets from suzisport for $9.00 for the pair
cheers,
Mark.
Post Posted: Wed Sep 03, 2008 10:33 pm
Part numbers for the shims are in my part numbers post in the tech section. You'll have to order these from Suzuki, though Suzisport etc could order them for you I think.
Post Posted: Wed Sep 03, 2008 11:17 pm
buy some shim material from the bearing shop and cut them out yourself. or as was suggested to me the other day cut up a coke can to use.
Post Posted: Fri Sep 05, 2008 12:40 am
cheers for all your help
Users browsing this forum: No registered users and 102 guests
