It is currently Sat Oct 03, 2026 3:14 am
lesspostingmorewheeling
Post Posted: Wed Sep 03, 2008 1:03 am
my zook has an imobolizer that only works when the battery has been disconnected and i don't have a remote for it
how would i go about removing it?
Post Posted: Wed Sep 03, 2008 1:35 am
why would you need an immobiliser if the battery is disconected? its already immobilised :)
1st step is to find it, 2nd step is to find where its been tapped into and then any factory wires that have been looped through it to rejoin
Post Posted: Wed Sep 03, 2008 2:09 am
it starts working when you connect the battery then the idicators flash and you can't start the car
where is the most common place they put them?
Post Posted: Wed Sep 03, 2008 6:30 am
Most are mounted under the drivers side dash, usually around the steering column area.
If its a name brand immobiliser like Laserline.... then it should only have black wires going into it making it a little hard to disable.
Post Posted: Wed Sep 03, 2008 11:04 am
just listen for it ticking with the indicators
see if you can find a small switch wired into it, turn the ignition on and flick the switch (may be a button) and it will override it
Post Posted: Wed Sep 03, 2008 11:09 am
They are usually wired into the ignition switch wiring so look for any factory wiring that has been cut and has (usually thinner) aftermarket wiring wired into it. If it's like most of the immobolizers I've had the displeasure of looking at over the years, there will be a birds nest of wiring under your dashboard. :roll:
Post Posted: Wed Sep 03, 2008 11:18 am
If it's like most of the zooks i've seen over the years, there will be a birds nest of wiring under your dashboard. :lol:
Vehicle: 105 landcruiser
Post Posted: Wed Sep 03, 2008 12:27 pm
i had same problem with my premier.. all of a sudden you would be at the lights ..have some sort of voltage fluctuation and the alarm would go off.
the horn was removed so it didnt make any sound.. the olnly way to turn it off was disconect the battery a few times...and it would also turn on when the battery was disconected.....
for a while (still am) i was runnin just a hot wire to the coil.. :) easiest fix
was a pain it the ass removing it and I'm left with spahetti and a massive massive headache even looking at rewireing it :'( main reason why its not mobile at the moment
Post Posted: Wed Sep 03, 2008 3:14 pm
WHILE ON THIS SUBJECT HOW DOES EVERYONE PROTECT THEIR RIGS FROM THEFT.
THIS IS MY CURRENT SYSTEM. MIGHT UPGRADE IT SOON TO HI TENSILE CHAIN.
Post Posted: Wed Sep 03, 2008 3:58 pm
In the year and a bit I have had my Zook I've never once had it tampered with. I don't usually bother locking it either. Maybe it is just where I live??
Post Posted: Wed Sep 03, 2008 4:10 pm
hmm good to know ;)
maybe you should invest in one of these Anti theft devices
Post Posted: Wed Sep 03, 2008 4:13 pm
I reckon that would deter any would-be thief :lol: :twisted:
Post Posted: Wed Sep 03, 2008 4:28 pm
dont bother then the you will have to upgrade the lock and it will just be a money pit..... :D
Post Posted: Wed Sep 03, 2008 5:00 pm
http://www.youtube.com/watch?v=lov9mdgO4G0
http://www.youtube.com/watch?v=8avOiTUc ... re=related
Vehicle: 75 Cruiser
Post Posted: Wed Sep 03, 2008 5:01 pm
is that so they can't adjust the seat? :lol:
Post Posted: Wed Sep 03, 2008 5:10 pm
Who would want to steal it with that carpet anyways
Post Posted: Wed Sep 03, 2008 7:16 pm
I NEED A TRUNK MONKEY!!!!!
Won't need the chaperone version for a few more years but the other versions I could do with now
Post Posted: Wed Sep 03, 2008 9:40 pm
hahaha I need a trunk monkey!!!!!
Post Posted: Wed Sep 03, 2008 9:45 pm
If my car is not in my driveway I'm either wheelin or it's within eyesight. Whilst it's in my carport, it's protected by my german shepard. ;)
Users browsing this forum: Google [Bot] and 161 guests
