| Author |
Message |
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sat Sep 06, 2008 12:28 am |
Apart from the obvious, is it the water pump wrong or the tensioner bearing? G16B 16 valve motor
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Sat Sep 06, 2008 12:30 am |
You mean because the other side of the belt is touching this side?
It looks ok to me...
Hint - change the timing belt and water pump at the same time...
royce
 Posted: Sat Sep 06, 2008 12:36 am |
whats a G16b twincam is a good start
I bet tensioner, I think all the waterpumps are the same in that area
looking at it the tensioner doesnt look right, do you have a front on pic?
Scrawny
 Posted: Sat Sep 06, 2008 12:39 am |
royce wrote: whats a G16b twincam is a good start
Suzuki
I was thinking maybe it was a G13 tensioner??
lump_a_charcoal
 Posted: Sat Sep 06, 2008 12:43 am |
Probably the same as the G13... Looks just like my one, in my 1300... I reckon the tensioner is right, what do you think the problem is with the pictures?
royce
 Posted: Sat Sep 06, 2008 12:46 am |
they made a g16 twincam?
my single cam  g16 16valve tensioner looks the same as a G13 one, and where that bolt is through the bearing doesnt look right
but I could be trippin too
Scrawny
 Posted: Sat Sep 06, 2008 12:51 am |
royce wrote: they made a g16 twincam?
Learnt something new didn't you
Or was it me?
lump_a_charcoal
 Posted: Sat Sep 06, 2008 12:54 am |
ScrawnC wrote: royce wrote: they made a g16 twincam?
Learnt something new didn't you Or was it me?
Bwaaha haaa haaa!
Does it have Hilux diffs too?
royce
 Posted: Sat Sep 06, 2008 1:00 am |
ok so I looked at some pics, yes I am on drugs and thats how the tensioner is
are the pulleys on properly? is the belt rubbing on teh cover?
I wonder if the belt would run out there if both pulleys were on back to front
lump_a_charcoal
 Posted: Sat Sep 06, 2008 1:01 am |
Could the bearing be on back to front? It looks like it has been like this for a while...
Scrawny
 Posted: Sat Sep 06, 2008 1:16 am |
Looks like it has done a fair bit of running like this alright. I'm suprised the belt hasn't 'walked' off the pulley. You might be right Lump, the bearing could be on backwards. I just pulled it all off as I'm replacing belt, bearing and water pump.
I'm guessing the apprentice did this one
I had it stuck in my head that 16 valve was twin cam for some reason, even though I knew it only had one cam.... must be the drugs
royce
 Posted: Sat Sep 06, 2008 1:19 am |
ooo now I looked at the pics properly
looks like the slot for the adjusting bolt thingo doesnt go round far enough, I once saw a 1.3 that it went too far so perhaps its a 1.3 one?
Scrawny
 Posted: Sat Sep 06, 2008 1:23 am |
There was absolutely no adjustment for the belt, the tensioner wouldn't move to allow slack. You may be right Royce.
Sorry, no front on pics
nissvit
Joined: Sun Apr 06, 2008 11:30 pm Posts: 184 Location: Brisbane
 Posted: Sat Sep 06, 2008 1:29 am |
can't see much from the angle of the pic.
this is what the last one I pulled apart looked like..
royce
 Posted: Sat Sep 06, 2008 1:31 am |
bloody arty photographer types
so its a single cam 16valve
MAKE SURE YOU DO THE FRIGGEN CRANK BOLT UP PROPERLY!!!!!!!
and have a look the woodruff key isnt already flogged
royce
 Posted: Sat Sep 06, 2008 1:32 am |
lump_a_charcoal
 Posted: Sat Sep 06, 2008 1:33 am |
Ah i see the problem now...
Yeah looks totally different to the 1.3 version i have, but remember there is another 1.3 motor, with a different water pump (dont know the number), maybe it is from one of those.
Scrawny
 Posted: Sat Sep 06, 2008 1:35 am |
Thanks Chris,
mine is definately a G13 tensioner then. They had the spring horizontal and had moved the screw that secures the spring end to the hole you can see straight out from the bearing.
I've only just done a G13 timing belt and I thought this tensioner looked the same.
11_evl
Joined: Tue Apr 10, 2007 11:30 pm Posts: 846 Location: logan reserve, Brisb
 Posted: Sat Sep 06, 2008 1:44 am |
isnt there 2 different thinkness timing belts, maybe u have everything to suit the thicker belt bar the tensioner bearing??
_________________ 92 sierra, 40" treps, full hydro, F&R steer, 106"W
royce
 Posted: Sat Sep 06, 2008 1:47 am |
there is 2 different tooth profiles, but timing belts are a bit universal so its possible somebody could get one too long or short or wide that still fit
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Sat Sep 06, 2008 2:47 am |
Man, stop finding things wrong with my engine OK
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
BlueSuzy
 Posted: Mon Sep 08, 2008 9:17 pm |
Is that a slight oil leak i see?
Looks abit dusty/oily on the sump
Sori. Is that another problem with your motor?
