It is currently Tue Oct 13, 2026 9:47 pm
Post Posted: Mon Oct 10, 2011 7:27 am
as above. whats involved with the conversion? is a 25mm body lift enough?
what do i do so i can keep a sierra transfer? will it be ok with heavy towing?
a fella with a good condition 4 speed auto vit wants to swap for my shitbox vit
and i have always wanted a auto.
Post Posted: Mon Oct 10, 2011 8:06 am
Theres a thread here somewhere with a write up from Joe, not sure where tho??
Its got some pics etc.
http://auszookers.com/index.php?name=Fo ... ic&t=20147
3rd post down...
Can't see why it wouldn't tow ok, Matt's ute tow a trailer every day.
Tunnel will have to be modded...
Post Posted: Mon Oct 10, 2011 8:10 am
Matt's went in with custom engine mounts, gearbox mounts and a cut and reshape of the trans tunnel 8) Probably some other shit too, but I forget :lol:
Post Posted: Mon Oct 10, 2011 8:16 am
http://auszookers.com/index.php?name=Fo ... light=auto
Post Posted: Mon Oct 10, 2011 9:04 am
Custom square exhaust flange too :rofl:
Shep you game enough to weld sierra pannels yet?
Lil Foot!
Post Posted: Mon Oct 10, 2011 9:09 am
been working away de rusting my sierra since i gutted it :wink: just couldn't be stuffed with my build thread anymore
Post Posted: Mon Oct 10, 2011 9:13 am
How could I forget that...one of Matt's better ideas :lol: :lol:
Post Posted: Sun Nov 27, 2011 4:45 am
has any body seen one of these kits?
http://www.trailtough.com/index.php?pag ... &Itemid=53
Post Posted: Sun Nov 27, 2011 4:47 am
Retract my last comment....I think Pete used one of these kits for Matt's ute :roll:
Vehicle: '96 LWB trayback
Post Posted: Sun Nov 27, 2011 5:12 am
I'm about to whack the 4speed auto into my zook shep.
Using one of joe's output flange plates from the auto, and getting the jackshaft shortened to use the sierra transfer.
Custom mount for the rear of the box. Already running a heavy duty DIY cradle and tube mounts for the transfer.
I've got a 2" body lift, but still expecting lots of work with the angry hammer.
For the cost of that kit you linked, I can't see any benefits for the price.
You could shep up all those parts just as easily in no time.
Post Posted: Sun Nov 27, 2011 9:57 am
for $100 more then joes plate i get all the bits needed to slap it in and i will have it in 7-10 days. joe wouldn't give me a time frame for his plate.
plus i like to get stuff done as quickly as possible that way i avoid the risk of having a 10 year car project.
so has anyone had anything to do with this kit?
Post Posted: Sun Nov 27, 2011 7:59 pm
looks the goods so i think i will buy it.
https://acrobat.com/app.html#d=9BB9zOiHS3SrbM5chAU7MA
Post Posted: Sun Nov 27, 2011 9:07 pm
pretty hard to fuck that up
 Profile YIM
Post Posted: Sun Nov 27, 2011 10:28 pm
thats what i hope :D
Post Posted: Tue Jan 24, 2012 10:05 am
do you have to do anything with the speedo to compensate for bigger tyres?
ie will the auto kick down a gear to soon because the speedo thinks you are doing 65kph when you are really doing 90kph.
Post Posted: Tue Jan 24, 2012 10:17 am
Hmmmm.... Not sure on that one.
Guess that depends on your gearing aswell.
1.6 AW4 runs 4.6? diff, 1:1 high and 1:1 4th on 26.5" tyres.
Matt is running 4.1 diffs, 1.22 high and 1:1 4th on 28.5's and it works perfectly.
EDIT: 4th is OD, so 0.75:1 maybe.
And would the kickdown be triggered by speedo or tacho? I would have though engine RPM would dictate when kickdown occurs.....
Post Posted: Tue Jan 24, 2012 10:55 am
i am going to be 6.5 trans and 4.88 diffs according to the gearing calculator it will be 100kph at 4000rpm
Post Posted: Tue Jan 24, 2012 11:04 am
I had the same concern and couldn't find an answer.
I justified it to myself that it would work, based on the factory vitara having high/low range. Surely the auto would need to behave for both ratios, so altering final drive ratio in your sierra would present a similar situation.
Post Posted: Tue Jan 24, 2012 11:11 am
That would be fairly similar to stock auto vit anyway. Perhaps someone with an auto 1.6 could comment?
Post Posted: Tue Jan 24, 2012 6:21 pm
Its more the load on the box and your throttle position. in economic will 31's my car will drop below 2000 before it kicks back in top. bit more throtor a trailer on and it drops back earlyer
Post Posted: Tue Jan 24, 2012 10:29 pm
4000 at 100km seems a little high
I think My vit man in 5th is 3200 with 31
@ 110km/h . it sucks
3600/3800 would be nice
Post Posted: Tue Jan 24, 2012 10:56 pm
Yes but when I tow my boat I still want Power. Plus my next set of tyres will be35s
Post Posted: Wed Jan 25, 2012 12:01 am
Sell ya silverstones? :lol:. By the time ya go to 35's i should be able to afford them.
Users browsing this forum: No registered users and 269 guests
