It is currently Fri Sep 25, 2026 3:33 pm
lesspostingmorewheeling
Post Posted: Mon Sep 15, 2008 5:53 pm
i know this is gonna sound stupid but how do i bleed the brakes on my sierra?
i got a bit of an idea but i just want to make sure i do it right
Post Posted: Mon Sep 15, 2008 6:01 pm
Start at the left rear corner. Have someone sit in the drivers seat to pump the pedal. When the pedal is pushed and held, undo the bleed nipple to release the pressure then do up again. Get them to pump up the pedal hard again and hold it down. Once again, undo the nipple and release the fluid. As the fluid drops down in the reservior top it up with the new fluid. Repeat the bleeding till the fluid comes out clear. Then bleed the fronts using the same method. You can also bleed out the proportion valve on the R/H inside chassis rail under the drivers seat, not essential but sometimes they trap air.
Post Posted: Mon Sep 15, 2008 6:02 pm
so start at the left rear then do the right rear?
Post Posted: Mon Sep 15, 2008 6:05 pm
there is only one nipple on the rear so does both sides at once
you can leave the nipple open and pump the clean stuff through then pump up and relase bit till no air
be careful to not push the pedal to the floor, you can pickup crap in the cylinder and wreck it
Post Posted: Mon Sep 15, 2008 6:06 pm
Depending on model the brake line should run from chassis rail to diff, head off to the r/r then back across to the l/r. There shouldn't be a nipple on the r/r.
If there is a nipple on the r/r then do L/R, R/R, L/F then R/F.
Post Posted: Mon Sep 15, 2008 6:07 pm
if i was to do the proportion valve do i do that last?
Post Posted: Mon Sep 15, 2008 6:08 pm
I wouldn't bother unless you end up with a spongy pedal. If you do then, do it last
Post Posted: Mon Sep 15, 2008 6:42 pm
ok thanks for the info i'll go try it and see how it goes
Users browsing this forum: No registered users and 50 guests
