| tire and rim sizes.. need help http://auszookers.com/forum/viewtopic.php?f=5&t=29533 |
| Author: | albie200 [ Fri Jan 13, 2012 8:43 pm ] |
| Post subject: | tire and rim sizes.. need help |
i want to fit 33/12.5/15 kl71s or bighorns on my sierra.. can i fit them on 8 inch rims? i have enough lift for them to clear the guards. im currently running 32" buckshots with no rubbing.. just need some guidance.. cheers heres a vid running 31" silverstones http://www.youtube.com/watch?v=6986DVsC ... gD0m5y0q2t |
| Author: | SierraDan [ Fri Jan 13, 2012 8:46 pm ] |
| Post subject: | Re: tire and rim sizes.. need help |
They will go on an 8" rim. You'll need to figure out what offset will clear 12.5 wide tyres with your setup also. |
| Author: | shep [ Fri Jan 13, 2012 9:20 pm ] |
i have a set of 33" bighorns on 8" rims with -13 offset. works well. i am wt diffs with nt spring spacing |
| Author: | albie200 [ Sat Jan 14, 2012 4:55 am ] |
SierraDan wrote: They will go on an 8" rim. You'll need to figure out what offset will clear 12.5 wide tyres with your setup also.
i have -19 offset i think.. ill have to double check it though. also have one inch spacers that i run if im doing big angle stuff... cheers |
