Have you put it into a cup of boiling water? you should see it open, otherwise spend $15 on a new one. Unless it is already a new one then I'd take it back for another.
If its always running at 80ish, I would suspect it is working correctly.
But the fact it didnt open in boiling water.
How long was it in the water for? Was it boiling?
Sierra can run two different thermostats.
82c and 88c (180F and 192F)
I am trying a 88c with 30% bigger flow (larger valve apparently). Installed a vit thermoclutch fan too.
It runs slightly warmer, and hasn't shown any signs of overheating.
The 82c barely showed on the guage, almost all the time.
Users browsing this forum: No registered users and 117 guests
