http://auszookers.com/forum/
carpark max height limits
http://auszookers.com/forum/viewtopic.php?f=5&t=29672
Page 1 of 2
Author:  drewhoo [ Tue Jan 17, 2012 10:01 pm ]
Post subject:  carpark max height limits
Hi Guys
My zook is growth spurting from lift, bigger tyres, roof trays, etc, etc...
I'm just wanting a quick reply on what your local supermarket / carpark max height is. I use my zook as a daily and deciding whether or not to leave my roof cage on permanently (putting it at a scrape under 2m).
Also, if its a 2m height, would you trust going in very close to that limit?
My locals in Sydney:
Bondi Junction Westfield 2.0m
Harbourside: 2.0m
Author:  squibby [ Tue Jan 17, 2012 10:10 pm ]
Post subject:  Re: carpark max height limits
Under 2m should get you into most carparks. I run my jimny with the roofbox and 40mm lift on all year round. It's 2.2m. About 50% of under cover carparks are 2.1m and the other 50% are 2.2m or higher.. So far i've noticed that every modern car park in my area (Newcastle) built in the 2000's is at least 2.2m. The older ones are lower. But there is almost always an alternative car park or a non-covered part in the low ones, I think they provide it on purpose to cater for taller vehicles, so i haven't been caught out yet at large shopping centres. Small old supermarket car parks like at your local Franklins etc are a different story though.
Sometimes I have to bang my way through the hanging 2.1m sign to access the taller car park, but my box is plastic so i don't care.
Author:  abclarke [ Tue Jan 17, 2012 10:12 pm ]
Lowest I've seen is 2.2m so I'd say that should be fine :)
Author:  Damo [ Tue Jan 17, 2012 10:20 pm ]
Don't worry guys, only Vitaras have this problem :P
Invented
For
Shopping
:thefinger:
Author:  BlueSuzy [ Tue Jan 17, 2012 10:30 pm ]
I normally park offroad, in carparks. :lol:
Author:  BertZook [ Tue Jan 17, 2012 10:48 pm ]
Just go and have a drive to urs local carparks and check the signs
:helloo:
Author:  buzbox [ Tue Jan 17, 2012 10:56 pm ]
With the roof basket on I can't get into the main carpark for the shopping centre here. It was rather embarrassing getting 3 other cars to reverse so I can get out. They wern't too pleased either.
Even with the basket off it just clears.
Author:  SierraDan [ Tue Jan 17, 2012 11:05 pm ]
With 2" lift and 31's no basket I'm at 180 something cm tall.
Heaps of room.
Author:  Joshyboy26 [ Tue Jan 17, 2012 11:14 pm ]
they 'usually' allow about 100mm above the bar for safety so if you just clip it ull be ok just keep ur eye on the sprinklers etc.
although saying that i did get stuck in a carpark once the exit was on a ramp so i got jammed on the roof with my spotties and had to go on a bit of an angle to get out haha
Author:  TheOtherLeft [ Wed Jan 18, 2012 12:43 am ]
I've been to plenty of 1.8m carparks around Sydney. The problem with not being able to park in carparks is there isn't much of an alternative that is closeby - street parking can be hard to find and also less secure.
Author:  SuziBlu [ Wed Jan 18, 2012 1:05 am ]
1.8m car park, struth, that means many of us normal sized people could not come close to standing up in it ??? for real ??
Author:  MrRocky [ Wed Jan 18, 2012 1:14 am ]
i have worked in most buildings in perth cbd and there are some crazy small height limits under them 1.8-9 is pretty standard
which sucks cause im 1.95
Author:  squibby [ Wed Jan 18, 2012 1:16 am ]
I'll agree with that. I know for a fact that my set up is under 2.2m, but I still touch the hanging 2.2m sign at my local, so they are exaggerating a bit, the sign says 2.2m but it's hanging lower.
Author:  Gwagensteve [ Wed Jan 18, 2012 1:16 am ]
The 1,8m thing is typically liability related. There may be a couple of areas where the height dips under 2.0 (or whatever) around ducts, beams etc so the whole carpark gets a 1.8m limit so they don't have people going in there and smashing the place/ their car up because they couldn't see the low hanging bits.
I'd be surprised if the whole of the carpark had a 1.8 minimum - that wold just be really bad design.
Can't say I've seen anything under 1.95 myself.
Author:  HAYD0S [ Wed Jan 18, 2012 1:51 am ]
Australian Standards originally applied 1.8 metres. So yes, you will definitely find some aging buildings with this height clearance (e.g. Focus Apartments in Surfers Paradise).
Australian Standards (as of 2004) set the minimum vertical clearance to be 2.2 metres from all overhead obstructions, including sprinklers etc. However, from when the plans/drawings are first approved to the actual construction, you will definitely find areas where the height clearance is less than the standard (for example where air-conditioning units have been provided). The Myer Centre in Brisbane is a perfect example (check the damage next time you venture in)
Author:  Fatzook [ Wed Jan 18, 2012 3:52 am ]
Agreed. For that matter I've never seen a carpark under 2.2m. I'm 1.96m tall, so I would have to duck to walk through an underground carpark that was 1.8m. Even 2.0m would be a challenge. Can't say I've had to do this yet......
Author:  BlueSuzy [ Wed Jan 18, 2012 3:55 am ]
They probably go off the lowest point in the carpark. doesnt mean the whole carpark is 2.2 etc, just the lowest point.
Author:  zukenutter [ Wed Jan 18, 2012 10:12 pm ]
Haha, thanks for the reminder. I've been meaning to check my height for a while. Is 1.95m I always fit but some have been close.
When Mrs Zukenutter was driving my old Jim as a daily she wedged it under a car park ramp :( Ripped the basket off and drove the roof rails down into the sheet metal. Was nasty.
Author:  alien [ Wed Jan 18, 2012 10:28 pm ]
theres a carpark near me that 1.8m, my zuk just scrapes under the pole at the entry =) its an odd feeling driving fast under there - you kinda duck and flinch at every low hanging thing on the ceiling =) haha never hit anything though.
Author:  badonkadonk [ Thu Jan 19, 2012 3:21 am ]
Safe to say if you've got the space to have the basket stashed at home, leave it off.
Author:  larry [ Thu Jan 19, 2012 4:04 am ]
which is more of a hassle: taking the basket off, or not getting into carparks..
Author:  buzbox [ Thu Jan 19, 2012 4:25 am ]
taking the basket off....
It's easier just to deflate your tyres :lol:
Author:  Jester [ Thu Jan 19, 2012 4:54 am ]
i reckon gus's vit wouldnt get into the upstairs carpark at westlakes shopping centre, i like slapping the sign through the open roof of my vit which is no where near the size of gus's
Author:  atari4x4 [ Thu Jan 19, 2012 5:00 am ]
I'm to scared to visit the Westside incase i get stabbed, shot or car jacked & I try to avoid shopping centres like the plague.
Author:  stockman [ Thu Jan 19, 2012 5:17 am ]
or airdown to take the missus to westfield :lol:
Author:  Jester [ Thu Jan 19, 2012 5:37 am ]
They breed em tough in the western suburbs :twisted: :twisted:
Im not a big shopping centre person either
Author:  Chop [ Thu Jan 19, 2012 5:52 am ]
I see they cater for the locals! WEST END DRAUGHT FTW! :lol:
Author:  missmyljdaze [ Thu Jan 19, 2012 6:35 am ]
Observation city in Scarborough had 1.9m safety boards hanging on chains at the carpark entry points- which most 4wd vehicles found too low- so they would either just barge through or have a passenger hold the board up for them.
then they would complain about wiping out thier spotties or roofrack on the gas main in the lower carpark.....
:crazy:
I tried to get the boss to get rid of the light timber boards and replace them with a hefty piece of heavy steel tube hanging on trailer springs or similar but the manager didnt want to know about it.
dont know if they ever solved the problem.
stephen
Author:  alien [ Thu Jan 19, 2012 6:39 am ]
haha yeah that carpark is nuts... especially as you drive back up the spiral after going down, when the ramp ends the suspension unloads and the rear wheel get air... lol that was when mine was more stock, and it just missed the roof... prolly cant even drive in there now.
Author:  TheOtherLeft [ Thu Jan 19, 2012 6:44 am ]
:crazy:
That says something about the intelligence of some 4WDers.
Page 1 of 2 All times are UTC + 9:30 hours
