It is currently Fri Oct 23, 2026 10:16 pm
Post Posted: Thu Jan 19, 2012 12:20 am
as the title says i am getting some info for NT spacing. (ideas for a new build)
long story short has any one got some pics of this set up.? with the way the pumpkin sits i cant get my head around the way the perch will sit and enable u bolts to be used sitting on the side of the pumpkin.
cheers boys, n ladies
:D
Post Posted: Thu Jan 19, 2012 1:52 am
Look at cars with an NT setup.
Post Posted: Thu Jan 19, 2012 2:37 am
The WT diff housing is the same as the NT diff housing except the WT obviously wider, the pumpkin is the same so when you fit a WT diff to a NT the spring position in regard to the pumpkin will be the same as it as with a NT housing, it will look exactly the same as it did with the NT housing except that the wheel will be further away from the spring.
Post Posted: Thu Jan 19, 2012 9:36 am
Armsup you hit the nail on the head
 Profile YIM
Post Posted: Thu Jan 19, 2012 12:33 pm
Beautiful fellas. Not owning a NT ever before I didn't realize this. Sorry of it sounded stupid. Couldn't find anything in search tho. I did try I promise. :oops:
Vehicle: Sierra Utey!
Post Posted: Thu Jan 19, 2012 10:07 pm
You can see in this pic of my conversion where the original WT perches had been and where the new ones are tacked on.
My ute..
Users browsing this forum: No registered users and 776 guests
