It is currently Thu Sep 24, 2026 8:21 am
Post Posted: Wed Sep 17, 2008 12:28 pm
Is anyone running these gears? I want to know if they should be as loud as mine seem to be. The WRC-dog-cut-gearbox sound is going to get old pretty quick I think :x
Post Posted: Wed Sep 17, 2008 3:26 pm
Yeah. It's normal. I'm running Trail Gears 6.5:1.
Its only bad enough to annoy when driving fast enough (ie 4th or 5th low). And if doing enough driving at that speed i'd probably end up flicking back to high anyway...
Don't worry, It's only a suzi...
http://www.auszo
Post Posted: Wed Sep 17, 2008 5:02 pm
What about high range though? That's my problem at the moment.
Post Posted: Wed Sep 17, 2008 6:50 pm
shouldn't be that loud?
they definetly are a bit louder in 5th cruising on the highway, but nothing to annoy me, especially with the radio blaring trying to drown out the hum of the claws/baaap of the exhaust as well! :lol:
http://www.auszo
Post Posted: Wed Sep 17, 2008 6:56 pm
Adding another amp is in the works, and I got a snortier muffler to put on too :P
Post Posted: Thu Sep 18, 2008 2:02 am
i can just hear mine are you sure you ground enough out of the transfer case
mine is abit hard to get out of low range you need to hit it down but i dont know hat it would be
Post Posted: Thu Sep 18, 2008 10:51 am
Shifting in mine seems fine, it's just the whine that is annoying. I definitly ground out enough of the case.
Post Posted: Thu Sep 18, 2008 11:04 am
just wait till the shitty gears wear down and get a bit sloppier, then they will be fine :)
try some different oil perhaps?
Post Posted: Thu Sep 18, 2008 12:13 pm
[quote="royce"]just wait till the shitty gears wear down and get a bit sloppier, then they will be fine :)
try some different oil perhaps?[/quote
I'll try that, not sure what to go with though. Any suggestions?
Post Posted: Thu Sep 18, 2008 12:22 pm
maybe some real good quality synthetic transmission oil? something with a bit better buffering characteristics that will dampen it a bit?
sometimes engine oil shuts up gearboxes, but it might stuff your transfer :)
Vehicle: '92 Sierra
Post Posted: Thu Sep 18, 2008 12:50 pm
Even the 4.whateveras I put in mine whined in high range Damo. It went away pretty quick though. Might put some good quality synthetic transmission oil in the missus. See if that whine goes away.
Post Posted: Thu Sep 18, 2008 2:37 pm
rofl! farkin brilliant... be sure to post your results!
Web wheeler extroadinaire
Post Posted: Thu Sep 18, 2008 11:31 pm
I didn't know my wife had a sister?!?
Post Posted: Fri Sep 19, 2008 1:26 am
You blokes don't know the 2 magix words obviously...
"yes, dear" :oops:
Vehicle: Clown Car..
Post Posted: Fri Sep 19, 2008 2:28 am
so many good jokes to be said about that...
1. "its not just sex dear, its a dipstick, im checking your levels..."
2. "least it auto-drains once a month...."
3. "Warning- upshifting MAY result in explosion"
4. "if its hard to get in reverse, more oil needed"
ok i'll shut up...
Post Posted: Fri Sep 19, 2008 2:34 am
ahahahaha great call
Users browsing this forum: No registered users and 194 guests
