| 6:1 Rockhopper gears http://auszookers.com/forum/viewtopic.php?f=5&t=2971 |
| Author: | Damo [ Wed Sep 17, 2008 12:28 pm ] |
| Post subject: | 6:1 Rockhopper gears |
Is anyone running these gears? I want to know if they should be as loud as mine seem to be. The WRC-dog-cut-gearbox sound is going to get old pretty quick I think |
| Author: | Dee [ Wed Sep 17, 2008 3:26 pm ] |
| Post subject: | Re: 6:1 Rockhopper gears |
Yeah. It's normal. I'm running Trail Gears 6.5:1. Its only bad enough to annoy when driving fast enough (ie 4th or 5th low). And if doing enough driving at that speed i'd probably end up flicking back to high anyway... |
| Author: | Damo [ Wed Sep 17, 2008 5:02 pm ] |
DEEV8 wrote: Yeah. It's normal. I'm running Trail Gears 6.5:1.
Its only bad enough to annoy when driving fast enough (ie 4th or 5th low). And if doing enough driving at that speed i'd probably end up flicking back to high anyway... What about high range though? That's my problem at the moment. |
| Author: | Dee [ Wed Sep 17, 2008 6:50 pm ] |
shouldn't be that loud? they definetly are a bit louder in 5th cruising on the highway, but nothing to annoy me, especially with the radio blaring trying to drown out the hum of the claws/baaap of the exhaust as well! |
| Author: | Damo [ Wed Sep 17, 2008 6:56 pm ] |
DEEV8 wrote: shouldn't be that loud?
they definetly are a bit louder in 5th cruising on the highway, but nothing to annoy me, especially with the radio blaring trying to drown out the hum of the claws/baaap of the exhaust as well! Adding another amp is in the works, and I got a snortier muffler to put on too |
| Author: | bazook [ Thu Sep 18, 2008 2:02 am ] |
i can just hear mine are you sure you ground enough out of the transfer case mine is abit hard to get out of low range you need to hit it down but i dont know hat it would be |
| Author: | Damo [ Thu Sep 18, 2008 10:51 am ] |
bazook wrote: i can just hear mine are you sure you ground enough out of the transfer case
mine is abit hard to get out of low range you need to hit it down but i dont know hat it would be Shifting in mine seems fine, it's just the whine that is annoying. I definitly ground out enough of the case. |
| Author: | royce [ Thu Sep 18, 2008 11:04 am ] |
just wait till the shitty gears wear down and get a bit sloppier, then they will be fine try some different oil perhaps? |
| Author: | Damo [ Thu Sep 18, 2008 12:13 pm ] |
[quote="royce"]just wait till the shitty gears wear down and get a bit sloppier, then they will be fine try some different oil perhaps?[/quote I'll try that, not sure what to go with though. Any suggestions? |
| Author: | royce [ Thu Sep 18, 2008 12:22 pm ] |
maybe some real good quality synthetic transmission oil? something with a bit better buffering characteristics that will dampen it a bit? sometimes engine oil shuts up gearboxes, but it might stuff your transfer |
| Author: | Hybrid [ Thu Sep 18, 2008 12:50 pm ] |
Even the 4.whateveras I put in mine whined in high range Damo. It went away pretty quick though. Might put some good quality synthetic transmission oil in the missus. See if that whine goes away. |
| Author: | Pubic [ Thu Sep 18, 2008 2:37 pm ] |
rofl! farkin brilliant... be sure to post your results! |
| Author: | Rockhopper [ Thu Sep 18, 2008 11:31 pm ] |
Hybrid wrote: Even the 4.whateveras I put in mine whined in high range Damo. It went away pretty quick though. Might put some good quality synthetic transmission oil in the missus. See if that whine goes away.
I didn't know my wife had a sister?!? |
| Author: | Damo [ Fri Sep 19, 2008 1:26 am ] |
Rockhopper wrote: Hybrid wrote: Even the 4.whateveras I put in mine whined in high range Damo. It went away pretty quick though. Might put some good quality synthetic transmission oil in the missus. See if that whine goes away. I didn't know my wife had a sister?!? You blokes don't know the 2 magix words obviously... "yes, dear" |
| Author: | foolsp33d [ Fri Sep 19, 2008 2:28 am ] |
Hybrid wrote: Might put some good quality synthetic transmission oil in the missus. See if that whine goes away.
so many good jokes to be said about that... 1. "its not just sex dear, its a dipstick, im checking your levels..." 2. "least it auto-drains once a month...." 3. "Warning- upshifting MAY result in explosion" 4. "if its hard to get in reverse, more oil needed" ok i'll shut up... |
| Author: | Zook_Fan [ Fri Sep 19, 2008 2:34 am ] |
ahahahaha great call |
