| Coily Bull bar http://auszookers.com/forum/viewtopic.php?f=5&t=29723 |
| Author: | HarryHoudini [ Thu Jan 19, 2012 9:54 am ] |
| Post subject: | Coily Bull bar |
Hi,need more help,does anyone know if this is a Bull Bar off a Coily,seller says he's not sure what model Sierra its off and the distance between mounting points is 19cm?.TIA |
| Author: | Rusho [ Thu Jan 19, 2012 10:00 am ] |
| Post subject: | Re: Coily Bull bar |
It will fit either way. The chassis mounts are essentially the same. The only difference would be the taper that the coily front clip has. |
| Author: | atari4x4 [ Thu Jan 19, 2012 10:07 am ] |
Farmer Joe just called, he said something about wanting the gate for the sheep paddock back. |
| Author: | monley [ Thu Jan 19, 2012 10:11 am ] |
atari4x4 wrote: Farmer Joe just called, he said something about wanting the gate for the sheep paddock back.
You sure it wasn't Smiffkid calling you? |
| Author: | atari4x4 [ Thu Jan 19, 2012 10:16 am ] |
monkey wrote: atari4x4 wrote: Farmer Joe just called, he said something about wanting the gate for the sheep paddock back. You sure it wasn't Smiffkid calling you? funny you say that, i swear that suzuki WA had a thing going on with a local ally fab shop to create the gayest looking alloy bars in oz. |
| Author: | Fatzook [ Thu Jan 19, 2012 11:31 am ] |
HarryHoudini wrote: Hi,need more help,does anyone know if this is a Bull Bar off a Coily,seller says he's not sure what model Sierra its off and the distance between mounting points is 19cm?.TIA
That bar is home made, so there is NO WAY to tell if it will fit, other than trying to make it fit. It does not look like the mounts will fit the front of a sierra chassis. The distance between the mounting points is most certainly NOT 19cm! (19cm is shorter than your forearm, even if you are a midget!) And calling that contraption a bullbar is inaccurate to say the least. Judging by how its mounted, its closer to a nudge bar. I wouldn't pay more than its scrap value. ~$20 |
| Author: | HarryHoudini [ Thu Jan 19, 2012 8:43 pm ] |
Thanks for the replies,something not quite right,surely he would know what its off and yes it appears home made but i just want something to fit fishing rods on..He wants $100 so i guess it will show up for sale somewhere. |
| Author: | abclarke [ Thu Jan 19, 2012 9:11 pm ] |
Haha fuck $100 for that thing! |
| Author: | BertZook [ Thu Jan 19, 2012 11:51 pm ] |
monkey wrote: atari4x4 wrote: Farmer Joe just called, he said something about wanting the gate for the sheep paddock back. You sure it wasn't Smiffkid calling you? |
| Author: | ZookFan [ Fri Jan 20, 2012 9:21 am ] |
GOLD |
| Author: | steak_knife [ Fri Jan 20, 2012 9:24 am ] |
Fatzook wrote: That bar is home made, so there is NO WAY to tell if it will fit, other than trying to make it fit.
It does not look like the mounts will fit the front of a sierra chassis. The distance between the mounting points is most certainly NOT 19cm! (19cm is shorter than your forearm, even if you are a midget!) And calling that contraption a bullbar is inaccurate to say the least. Judging by how its mounted, its closer to a nudge bar. I wouldn't pay more than its scrap value. ~$20 All your stuff's home made to... |
| Author: | suzukikid [ Fri Jan 20, 2012 9:46 am ] |
$20 that a bit yuk! im gunna go clear the chuck out of my throat...... |
| Author: | atari4x4 [ Fri Jan 20, 2012 9:47 am ] |
steak_knife wrote: Fatzook wrote: That bar is home made, so there is NO WAY to tell if it will fit, other than trying to make it fit. It does not look like the mounts will fit the front of a sierra chassis. The distance between the mounting points is most certainly NOT 19cm! (19cm is shorter than your forearm, even if you are a midget!) And calling that contraption a bullbar is inaccurate to say the least. Judging by how its mounted, its closer to a nudge bar. I wouldn't pay more than its scrap value. ~$20 All your stuff's home made to... and not even made in a proper shed.... get some walls & a concrete floor Mr Fatzook. |
| Author: | Fatzook [ Fri Jan 20, 2012 11:17 am ] |
atari4x4 wrote: steak_knife wrote: Fatzook wrote: That bar is home made, so there is NO WAY to tell if it will fit, other than trying to make it fit. It does not look like the mounts will fit the front of a sierra chassis. The distance between the mounting points is most certainly NOT 19cm! (19cm is shorter than your forearm, even if you are a midget!) And calling that contraption a bullbar is inaccurate to say the least. Judging by how its mounted, its closer to a nudge bar. I wouldn't pay more than its scrap value. ~$20 All your stuff's home made to... and not even made in a proper shed.... get some walls & a concrete floor Mr Fatzook. Have walls. Have concrete too. 7x7m slab actually. Its just not as close to my tools as my other work areas. My fab table doesn't care what the ground surface is underneath it |
| Author: | Fatzook [ Fri Jan 20, 2012 11:19 am ] |
steak_knife wrote: Fatzook wrote: That bar is home made, so there is NO WAY to tell if it will fit, other than trying to make it fit. It does not look like the mounts will fit the front of a sierra chassis. The distance between the mounting points is most certainly NOT 19cm! (19cm is shorter than your forearm, even if you are a midget!) And calling that contraption a bullbar is inaccurate to say the least. Judging by how its mounted, its closer to a nudge bar. I wouldn't pay more than its scrap value. ~$20 All your stuff's home made to... So? My point was that because its home made, there is no way to identify if its for a sierra or not. Can you say that about my products?
| Author: | atari4x4 [ Fri Jan 20, 2012 11:20 am ] |
so you just roll around in the dirt with rusho for fun |
| Author: | Fatzook [ Fri Jan 20, 2012 11:22 am ] |
atari4x4 wrote: so you just roll around in the dirt with rusho for fun
No. You're looking at it all wrong. A coily isn't good enough to justify the use of concrete floors |
| Author: | ZookFan [ Fri Jan 20, 2012 11:27 am ] |
GOLD mr Fat |
