It is currently Thu Oct 15, 2026 7:03 am
Post Posted: Fri Jan 20, 2012 5:36 am
seems like the automatic choke stays on and revs at about 2000rpms when at a stop, how do you fix ?
Vehicle: '91 Sierra, Fluffy Dice.
Post Posted: Fri Jan 20, 2012 9:15 am
Have you checked the stop behind the Accelerator?
Also, what is it? a few more details would help
If at first you don't succeed, get a bigger hammer
Post Posted: Fri Jan 20, 2012 10:36 am
check your coolant isn't low
Post Posted: Fri Jan 20, 2012 11:11 am
Mine does the same thing. The coolant passages in my carby are corroded solid!
My solution until i can find a new carby or something was to re-set the idle so it revs at about 1200 when hot which means about 300 rpm for the first minute or two when cold.
I cant bring myself to spend $600 on a reco carby from suzistore :(
Post Posted: Tue Jan 24, 2012 5:27 am
My Zooker is an 1986 sierra 1.3 there isn't anything behind the accelerator and everything looks ok and when it starts up it's fine but once it starts to warm up it just stays at about 2000 rpm. maybe its the coolant passages ? not sure evry time I muck around with I seem to do more damage to it.
Post Posted: Tue Jan 24, 2012 9:02 am
If you twist the accelarator linkage on the carby (half round thing the cable goes on) twist it up to full throttle you will see a screw underneath, turn it 1/2 or one turn anticlockwise, I think this ajusts the choke revs.
BTW with the engine off.
Users browsing this forum: Google [Bot] and 288 guests
