It is currently Thu Oct 15, 2026 8:51 pm
Post Posted: Fri Jan 20, 2012 8:46 pm
Hi i have just bought an 1976 suzuki carry van. That has the lj50 two stroke
engine and thought that there would be some here who own the lj50 4x4 that use the same engine.
I would like to know what oil peaple here use for there two stroke engines in the oil tank and also how
much oil they should use compared to fuel use hope that sounds right?
Thanks Jamie
Post Posted: Fri Jan 20, 2012 8:48 pm
Thanks Jamie
If it is a 76 Carry it is an L60 and is a 446cc 2 cylinder 2 stroke.
A different engine to the 3 cyl LJ50.
This is my old one...
[img][IMG]http://i121.photobucket.com/albums/o221/want33s/l60.jpg[/img][/img]
Post Posted: Fri Jan 20, 2012 8:54 pm
This has the lj50 motor it has a sticker under the dash that says engine is lj50 and the engine has lj50 stamped on it also it is 3 cylinder 539cc.
Post Posted: Fri Jan 20, 2012 8:59 pm
OK.. Yours must be the first of the "ST's". Lucky bugger!.
Yours has horizontal door handles yeah?
Castrol recommend CASTROL POWER 1 TTS RACING
http://www.datateck.com.au/lube/castr_au/default.asp
2stroker or 3cyl would be the guys to ask.
Mine used to smell unreal running avgas and castor oil.
Post Posted: Fri Jan 20, 2012 9:25 pm
Must be one of the first i was told buy the origanal owners relative how inherited the van that it was a 76 and it has 76 on the seat belts so i pesume its a 76 it has the same door handles as your one.
Vehicle: 92 Suzuki Sierra
Post Posted: Fri Jan 20, 2012 11:14 pm
I use gulf western outboard motor oil on all my 2 strokes engines (including some vintage suzuki 2t bikes in the past)
Its about $25 for 4L and has a tcw3 rating, has burnt really clean in all the engines(including some dubious salvaged victas of the 50's/60's) In premix engines i even lean out the ratio a little (ie 50:1 recomened then i mix 75:1 with no signs of extra wear after years of use)
I had noted that most 2T oil that have the Japanese JASO FC rating have the american TCW-3 rating as well in motorcycle oils. i like to think that since the oil colour and consistancy appears the same in an outboard oil and a specialty motorbike oil of the same brand that its the same oil.
Either way if i'm right or wrong the point is moot as such an old suzuki engine like the LJ50 ran on the older smoky JaSO FB and most manufacturer manuals of that vintage even listed straigt 30W as an alternative. TCW-3 will be much better than FB (which is only $3 cheaper in gulf western brand at supercheap), is easier on the oil-injection system and will not leave a smoky haze in your wake.
If i score a 2t suzuki car its what i'll be using in it
-Santos
Post Posted: Fri Jan 20, 2012 11:39 pm
ive done over 4,000kms in mine since purchase, not so many now the novelty has worn a little. I have found the motorbike 2 stroke a little to thin for my liking and the car doesnt run as well or start as well on it compared with some of the older style 2 strokes for boats and mowers.
may not be right but thats just my personal experience.
Post Posted: Sat Jan 21, 2012 7:19 am
Great thanks for the help and ideas.
Cheers Jamie
Vehicle: LJ50V, SJ70
Post Posted: Sun Jan 22, 2012 3:24 am
Some discussion on 2 stroke oils IN THIS THREAD
An LJ50 uses about 1 litre of oil per tankful (27lts). The oil tank is 2.5lts.
Post Posted: Mon Jan 23, 2012 11:22 am
Thanks 303zuke that gives me a great idea of the oil consuption the vans oil tank holds 3.7 lts.
Thanks jamie
Users browsing this forum: Google [Bot] and 340 guests
