Joined: Mon May 16, 2011 8:00 am Posts: 75 Location: Tassie
Posted: Sat Jan 21, 2012 6:11 pm
In addition to the coolant from via the gasket at the base of the carby another possible cause or atleast it might contribute is a sticky ERG valve (the vacuum controled Exhaust Recirculation System) under the carb on the manifold.
I blocked mine with a shim.
This may explain why it ran crook with the new carby and changed after driven hard.
I also cleaned the PCV, hoses and iside of rocker cover which were blocked with shit,
Users browsing this forum: Google Adsense [Bot] and 450 guests
