| hilux cv sierra knuckles? http://auszookers.com/forum/viewtopic.php?f=5&t=29813 |
| Author: | Brett [ Sun Jan 22, 2012 9:44 pm ] |
| Post subject: | hilux cv sierra knuckles? |
Just a quick question. does a hilux cv fit inside a sierra knuckle? |
| Author: | want33s [ Sun Jan 22, 2012 10:04 pm ] |
| Post subject: | Re: hilux cv sierra knuckles? |
Brett wrote: Just a quick question. does a hilux cv fit inside a sierra knuckle?
No.. In fact a hilux CV only JUST fits in a hilux knuckle. They have flats machined into the bell to enable install and removal. |
| Author: | Brett [ Sun Jan 22, 2012 10:35 pm ] |
Well that killed the idea i had then. thanks any way |
| Author: | SierraDan [ Sun Jan 22, 2012 11:42 pm ] |
want33s wrote: Brett wrote: Just a quick question. does a hilux cv fit inside a sierra knuckle? No.. In fact a hilux CV only JUST fits in a hilux knuckle. They have flats machined into the bell to enable install and removal. x2 they dwarf Sierra cv's. Even chromos are a tight fit. |
| Author: | tanshi [ Tue Oct 30, 2012 10:35 am ] |
any one know what a GU patrol cv is like in comparison to hilux? also any could some one measure the diameter of the lux front axle tube on the outer end... |
| Author: | joeblow [ Tue Oct 30, 2012 10:41 am ] |
tanshi wrote: any one know what a GU patrol cv is like in comparison to hilux? also any could some one measure the diameter of the lux front axle tube on the outer end... It's hugerer. |
| Author: | sideways [ Tue Oct 30, 2012 11:10 am ] |
joeblow wrote: tanshi wrote: any one know what a GU patrol cv is like in comparison to hilux? also any could some one measure the diameter of the lux front axle tube on the outer end... It's hugerer. x2 They're massive. |
| Author: | tanshi [ Tue Oct 30, 2012 11:16 am ] |
how massive? measurment? the specs i have say they are 90mm diameter on the bell |
| Author: | BlueSuzy [ Tue Oct 30, 2012 11:55 am ] |
Lux axle tube OD from memory 80mm |
| Author: | tanshi [ Tue Oct 30, 2012 1:07 pm ] |
GQ is 93mm diameter GU is around 10mm bigger Some one got a chromo Sierra CV around they can measure a diameter for me? |
| Author: | zooky08 [ Tue Oct 30, 2012 2:50 pm ] |
tanshi wrote: GQ is 93mm diameter GU is around 10mm bigger Some one got a chromo Sierra CV around they can measure a diameter for me? Edit: 82mm |
| Author: | sideways [ Wed Oct 31, 2012 2:06 am ] |
I got 83.6mm. |
| Author: | SierraDan [ Wed Oct 31, 2012 2:12 am ] |
Get the micrometer out |
| Author: | sideways [ Wed Oct 31, 2012 2:29 am ] |
SierraDan wrote: Get the micrometer out I wish I had a 75-100mm micrometer so I could make a smartarse comment here.
| Author: | zooky08 [ Wed Oct 31, 2012 4:48 am ] |
i used a tape measure |
| Author: | SierraDan [ Wed Oct 31, 2012 5:13 am ] |
sideways wrote: SierraDan wrote: Get the micrometer out I wish I had a 75-100mm micrometer so I could make a smartarse comment here. ![]() Ive got one. No chromos but |
| Author: | Teracis [ Wed Oct 31, 2012 6:23 am ] |
What the hell are you buggers doing measuring chromos at 2am... |
| Author: | SierraDan [ Thu Nov 22, 2012 1:54 pm ] |
sideways wrote: I got 83.6mm. I got 83.7mm (pretty crap tolerances Lux chromo i got 93.6mm |
