| Engine Numbers - G16B . 8 or 16 Valve? http://auszookers.com/forum/viewtopic.php?f=5&t=29885 |
| Author: | krat [ Wed Jan 25, 2012 3:40 am ] |
| Post subject: | Engine Numbers - G16B . 8 or 16 Valve? |
Hi all, I've been looking to buy my first suzuki and have been checking this site for a few months to gather some info. What a great site for advice and help. I have done numerous searches after thinking I had read something about this but can't find the thread. Hence I need some advice. Does the engine or vin number give any clues as to the number of valves the engine has? Secondly, I am looking at a 96 SWB vitara with fuel injection. Does this mean its a 16valve or 8. And in your opinions does it matter' Is there an advantage of the 16 over the 8 in the long run. Also, what is the general opinion on this model. Thanks in anticipation, Kev. |
| Author: | Fatzook [ Wed Jan 25, 2012 3:45 am ] |
| Post subject: | Re: Engine Numbers - G16B . 8 or 16 Valve? |
16v. All G16Bs will be 16v, UNLESS they have been tampered with. G16A carby models are all 8v's. You can also get G16A TBI 8v's, and G16A import 16v's too. But a 96 model will be a 16v for sure. Clear as mud? |
| Author: | royce [ Wed Jan 25, 2012 4:01 am ] |
96 is not only 16 valve, it uses the later coil in dissy 'x90' engine and has the same dash as the 2 litre Vitaras |
| Author: | Fatzook [ Wed Jan 25, 2012 4:28 am ] |
royce wrote: 96 is not only 16 valve, it uses the later coil in dissy 'x90' engine and has the same dash as the 2 litre Vitaras
Fully sick |
| Author: | Damo [ Wed Jan 25, 2012 4:31 am ] |
Fatzook wrote: 16v.
All G16Bs will be 16v, UNLESS they have been tampered with. G16A carby models are all 8v's. You can also get G16A TBI 8v's, and G16A import 16v's too. But a 96 model will be a 16v for sure. Clear as mud? Just to make things even more confusing, my X90 1.6 16v engine has a g16a block. I don't think there is a 16v/g16b 8v/g16a correlation, it appears to be inconsistant in my experience. |
| Author: | Fatzook [ Wed Jan 25, 2012 4:38 am ] |
Damo wrote: Fatzook wrote: 16v. All G16Bs will be 16v, UNLESS they have been tampered with. G16A carby models are all 8v's. You can also get G16A TBI 8v's, and G16A import 16v's too. But a 96 model will be a 16v for sure. Clear as mud? Just to make things even more confusing, my X90 1.6 16v engine has a g16a block. I don't think there is a 16v/g16b 8v/g16a correlation, it appears to be inconsistant in my experience. Was your x-90 a local or import motor? If its an import ( like mine was ) it will always be a G16a. |
| Author: | Damo [ Wed Jan 25, 2012 4:54 am ] |
Fatzook wrote: Damo wrote: Fatzook wrote: 16v. All G16Bs will be 16v, UNLESS they have been tampered with. G16A carby models are all 8v's. You can also get G16A TBI 8v's, and G16A import 16v's too. But a 96 model will be a 16v for sure. Clear as mud? Just to make things even more confusing, my X90 1.6 16v engine has a g16a block. I don't think there is a 16v/g16b 8v/g16a correlation, it appears to be inconsistant in my experience. Was your x-90 a local or import motor? If its an import ( like mine was ) it will always be a G16a. Not 100% sure of that. I was told it was local, but take that with a pinch of salt as the guy couldn't tell his arsehole from a hole in the ground. |
| Author: | christover1 [ Wed Jan 25, 2012 5:13 am ] |
My import Baleno engine recently fitted to my Vitara is G16A 16v EFI. Supplier/importer had G16B's but they were all TBI (I think 8v) |
| Author: | krat [ Thu Jan 26, 2012 7:24 am ] |
Thanks for the responses all. It looks like as a stock vitara then it will be the 16valve model. Is there a real advantage of the 16v over the 8v model. Thanks kev. |
| Author: | Gwagensteve [ Thu Jan 26, 2012 7:40 am ] |
krat wrote: Is there a real advantage of the 16v over the 8v model.
Thanks kev. Massive difference. 16V is the only way to go. Steve. |
