It is currently Wed Oct 14, 2026 5:47 am
Post Posted: Wed Jan 25, 2012 9:16 pm
Hi guys, just discovered my rear wheel bearings are stuffed again (damn mud!) and I'm going away 4wdin this weekend. I went to my local parts store to order some, I asked for SJ70 bearings, (I have an 88.5 SJ50) and they are a fair bit different to the ones already on there. The new ones are about 20mm wide, 35mm id and 72mm od and they have an o-ring around the outside. the old ones are just the standard wt ons with the spacer built in. Will the new ones I got work?
Post Posted: Wed Jan 25, 2012 9:32 pm
Can you post up some pics? If they're not the same dimensions then they won't fit (not sure what dimensions they should be)
Post Posted: Wed Jan 25, 2012 9:38 pm
Unfortunately not, I am at work and camera is at home.
Post Posted: Wed Jan 25, 2012 9:45 pm
Do you have a part number? Where'd you get them from?
Post Posted: Wed Jan 25, 2012 9:49 pm
Old bearing:Koyo DG357222DW New bearing:NSK 835-80A
Post Posted: Thu Jan 26, 2012 12:13 am
Bump, please help, need to get it going before the weekend :please:
Post Posted: Thu Jan 26, 2012 12:24 am
they are the same bearings i have in my 89 wt sierra i believe it also has the built in spacer so make sure the bearing is pressed on the right way.
oil lights are like oven alarms, let u know its co
Post Posted: Thu Jan 26, 2012 12:25 am
Pm Weaves, he'll soon tell you
Post Posted: Thu Jan 26, 2012 12:35 am
The new ones? How do you know? Same part number?
Post Posted: Thu Jan 26, 2012 12:37 am
yeah same part number i did a rear wheel bearing two weeks ago had trouble finding them the outside diamiter was the clincher for me i measured mine came up with same measurement.
Post Posted: Thu Jan 26, 2012 12:38 am
The DG357222DW is the right one.
Never heard of the NSK one, its not a brand i sell regular.
The bearing itself NEEDS to be 35 id, 72 od and 17 wide, and have a spacer of 5mm.
The oring is something you can remove, you don't need it, and if by o ring you mean circlip, same goes, remove it, its not needed in this application
Sounds like you got NT not WT bearings
the difference is the NT doesn't have the spacer built into the bearing (on the inner ring) like the WT ones do.
the bearing you removed is the WT bearing.
I hope my ramblings make sense
Post Posted: Thu Jan 26, 2012 12:44 am
Well the new bearing is the same width overall as the other one so will it work? And it is definitely an o-ring. Reason why I am persisting with these ones is that the other ones are an extra $100!
Post Posted: Thu Jan 26, 2012 12:47 am
Fark me, they are stinging people over there.
is it the same width INCLUDING the spacer ring on the DG357222DW?
basically I'm asking is it 22 or 17 wide?
Post Posted: Thu Jan 26, 2012 12:48 am
New one is 22 wide. It has a very small spacer bit on the outside and the bearing is wider if that makes sense?
Post Posted: Thu Jan 26, 2012 12:50 am
the ones that are an extra $100 could be the same thing but heavey duty
mine cost $38
No. Different bearing.
Post Posted: Thu Jan 26, 2012 12:53 am
Well technically speaking, the bearing will only take up the extra space of the spacer. it won't sit any further out on the inner edge.
it just means the bearing might sit against the backing plate.
and from memory there isn't much, if anything it can damage beside the bearing itself.
my Opinion would be it will work, but not sure for how long.
Ive never done this myself or know anyone thats run that bearing themselves. So its purely OPINION and shouldn't be taken for FACT
Post Posted: Thu Jan 26, 2012 12:55 am
Ok may have a closer look.
Post Posted: Thu Jan 26, 2012 12:57 am
aslong as you put the spacer to the outside, and the inner ring (including the spacer) matches up to the width of the one that came out. Its worth giving a shot in my mind
Post Posted: Thu Jan 26, 2012 1:03 am
lol, and if it ends up wrong just lathe 3mm off your brake drums..........
Post Posted: Thu Jan 26, 2012 1:07 am
i've read that before recently on here, speaking from experience? :lol: :P
you got home from memory? 8)
Post Posted: Thu Jan 26, 2012 1:08 am
A lathe is a machine NOT a machining operation.
Post Posted: Thu Jan 26, 2012 1:09 am
lol, nothing fancy like a lathe i had to use a bench grinder cause the ass who pressed my bearings on put them on back to front. i did get home ok and i probally could have left them like that but i like it done properly.
Post Posted: Thu Jan 26, 2012 4:13 am
well if it means that much to you....
"And if it end up wrong, just machine 3mm off you're brake drum".
:roll: :roll: :roll:
I assure you everyone knew what I was talking about
Post Posted: Thu Jan 26, 2012 4:24 am
You don't need a lathe to do what you describe. There are several other machines that would be perfectly acceptable to use.
Post Posted: Thu Jan 26, 2012 4:28 am
obviously, I have stated that I used a bench grinder, Hand grinder would have been better but none availabe at the time. It's a mute point anyway. Using said info from forum members I'm sure none of this will be needed as it will be done properly the first time.
Post Posted: Thu Jan 26, 2012 7:55 pm
:P It worked! Small gap between backing plate and housing but it'll be fine. :roll:
Post Posted: Thu Jan 26, 2012 8:02 pm
pompoms
Post Posted: Thu Jan 26, 2012 9:39 pm
:P YAY! Now I can go and destroy the new bearings in some mud this weekend :roll: :lol:
Post Posted: Fri Jan 27, 2012 12:28 am
Good to see it worked out.
Users browsing this forum: No registered users and 229 guests
