| G16B Alternator http://auszookers.com/forum/viewtopic.php?f=5&t=29910 |
| Author: | Mrhb2u [ Thu Jan 26, 2012 1:03 am ] |
| Post subject: | G16B Alternator |
I know upgrading alternators has been discussed in the forums but I am unable to find anything specific for the G16B. Could anyone advise what alternator would easily fit increasing the output and what I would need for this... bracket, plugs etc... I did purchase a 2nd hand Ford 110amp but I think its the wrong version?! Much appreciated! |
| Author: | Plum [ Thu Jan 26, 2012 9:33 am ] |
| Post subject: | Re: G16B Alternator |
I haven't done the ford one, but Piranha do a kit for them. It's not cheap though, about $400 I think |
| Author: | Boneheimer [ Thu Jan 26, 2012 10:32 am ] |
What's wrong with the ford alt? Is it a ef/el? |
| Author: | Gwagensteve [ Thu Jan 26, 2012 7:46 pm ] |
Ford all the way. No reason to look at anything else. I assume the G16B is in a sierra based on your avatar? It's a nightmare to fit a bigger alternator onto a G16B in a vitara, but it is possible. Steve. |
| Author: | Mrhb2u [ Thu Jan 26, 2012 9:13 pm ] |
That's correct Steve, it is in a Sierra. On further investigation I was sold the incorrect unit and ended up with an AU Ford alternator instead! I'm guessing the EL version is what I'm after? Anything else I will need to go with it? |
| Author: | Boneheimer [ Thu Jan 26, 2012 9:29 pm ] |
Have a good read of this Alt. Upgrade JrZook wrote: 4wheeljive wrote: is this going to work on a g16b??? Yes! But I found is you use the stock cast mount on the g16B the alternator will be wayyy off alignment. Find a 1.3 metal alternator bracket and drill it out. Dan Ripped straight from there regarding G16 |
| Author: | Mrhb2u [ Thu Jan 26, 2012 10:21 pm ] |
Awesome! Thanks Boneheimer |
