hey guys, i have a 92 soft top sierra and i have a lot of play in my steering i was just wondering if any off you guys know how to fix this? thanks, Haurp00ned
Posted: Sat Jan 28, 2012 6:10 pm
Check:
Tierod ends- no play in them, helps with 2 people, 1 to steer back and forth, 1 to check uni joint in steering shaft-no play in it. rag joint-not ripped If all else is good, try adjusting the screw in the top of the steering box. Little bit at a time,Dont screw it in too much, Where your steering is centered, thats where all the wear will be. So if you adjust when the steering is nice and tight when wheels are straight, you might not be able to turn!
Users browsing this forum: No registered users and 322 guests
