It is currently Fri Oct 16, 2026 12:08 am
Post Posted: Sun Jan 29, 2012 6:00 pm
Is the front diff in an SJ70 an LSD?
Is the rear diff an LSD standard?
Can the rear diff be swapped to the front?
Is there an advantage of having an LSD in the front and rear?
The Zooks of Hazzard
Post Posted: Sun Jan 29, 2012 6:02 pm
they are not lsd and they can not be swaped
if u drive a loud toyota ute u drink rum
Vehicle: 03 Jimny
Post Posted: Sun Jan 29, 2012 6:40 pm
Third member can be swaped front and back
Not sure about center.Front is 22 spline rear is 26 pline so depends what you trying to swap
No LSD in a Sierra in aus as far as I know
Post Posted: Sun Jan 29, 2012 6:47 pm
AFAIK only LSD were fitted OS. Not worth the effort to fit a LSD IMO.
Post Posted: Sun Jan 29, 2012 7:34 pm
All parts are interchangeable the side gears mean the difference between what end you can put it in.
With chromoly front axles with 26 spline a rear (26spline side gears) can go either end.
Post Posted: Mon Jan 30, 2012 8:27 am
Ok thanks all.
In your opinion is it worth having a locker for beach work? beach work while towing a camper trailer?
Post Posted: Mon Jan 30, 2012 9:39 am
Maybe a rear. I find my front digs holes.
Users browsing this forum: No registered users and 302 guests
