It is currently Fri Oct 16, 2026 7:38 pm
Post Posted: Sun Jan 29, 2012 6:12 pm
Has anyone had there door stop closing properl? Mine has stopped latching can this be fixed or do I need a new latch.
Its currently sticky taped shut and im not to keen on using passenger door for much longer.
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Sun Jan 29, 2012 6:15 pm
Yeah the latch has quite a few moving parts in it. Probably best to pop your door card off and see if the link rods etc are jamming it. You may nee to remove both side door cards to compare the working one to the dead one.
Should be something simple though. May just need a good clean and lube.
Vehicle: 03 Jimny
Post Posted: Sun Jan 29, 2012 6:24 pm
also make sure the latch on the b pillar side hasn't moved.
Post Posted: Sun Jan 29, 2012 6:25 pm
Good point. Its called the 'striker' BTW :wink:
Post Posted: Sun Jan 29, 2012 6:58 pm
Thanks lads job for tomorrow night
Post Posted: Mon Jan 30, 2012 9:07 pm
hey if you need a new latch i have one here working u can grab
Phuck Photobucket
Post Posted: Tue Jan 31, 2012 8:06 am
will let ya know ben you seen how anoying this is on the weekend.
Vehicle: '92 Sierra
Post Posted: Tue Jan 31, 2012 8:21 am
Have you tried manually testing the latch by pushing on the tongue with your finger? It could be that the mechanism is fine but the door hinges have sagged slightly so that it's out of alignment. There's adjustment (play) in the strike and latch to realign this if I remember correctly.
Post Posted: Tue Jan 31, 2012 10:00 am
hybrid, i havent had a chance to play with it yet. however its not taped up and its shut today. i will have a look tonight hopefully its an easy fix thanks for the help lads
Users browsing this forum: Google [Bot] and 300 guests
