It is currently Thu Oct 29, 2026 6:53 am
Post Posted: Thu Feb 02, 2012 12:42 pm
Hi all, does anybody have ome long travel shocks on there vitara? If so do they make them for the rear and how much are they? Cheers brad
Post Posted: Thu Feb 02, 2012 1:05 pm
OME make a shock to suit their 40mm lift, if you're after something longer you'll need to look at other options. do you specifically need the OME shock?
check out the vitara/commodore shock thread in goodtech viewtopic.php?f=17&t=13142
Post Posted: Thu Feb 02, 2012 1:08 pm
after a quick search in google and auszookers.
rear shocks (bommadore)
front and rear (4wd1)
http://www.4wd1.com/Vitara.htm
probably quicker than the time it took to write this post :wink:
Post Posted: Thu Feb 02, 2012 1:19 pm
Any one know of any other shocks that fit that are stiffer then commo ones
I'm really thinking there way to soft for my car
Post Posted: Thu Feb 02, 2012 1:26 pm
Thanks atari I just wanted to. Get a bigger shock absorber Thant the tough dog one because I just got some 30mm coil spacers and I want to be able to make it flex that little bit more
Vehicle: 89 Vit. The Desert Rat...
Post Posted: Thu Feb 02, 2012 4:58 pm
I use Falcon XR6 II shocks in the rear of my SWB. They're a straight bolt on fit. No mucking around with the bushes.
They're a Munroe shock #WR2T (If i remember rightly) and they work well with my 50mm lift king springs.
Springs are pretty stiff though.
Katherine 2013!
Post Posted: Thu Feb 02, 2012 7:02 pm
part # or open-closed length?
Post Posted: Thu Feb 02, 2012 8:29 pm
They're standard Falcon XR6 series II shocks made by munroe and the part number is wr2t-18080.
I don't know the open or closed lengths, here's a pic.
The white shock is the pedders comfort shock that was in there when I got the car. The red one is falcon.
The black spring is OEM the yellow is king.
Haven't tried it in the bush yet but it's pretty stiff on the road and seems to handle pretty well.
This setup gave me an unloaded lift of 65mm and cost $20. Ok the shocks were free.
Katherine 2013!
Post Posted: Sat Feb 04, 2012 12:42 am
Ranchos? Royce?
Users browsing this forum: Google [Bot] and 289 guests
