| Slipping clutch http://auszookers.com/forum/viewtopic.php?f=5&t=30193 |
| Author: | zookdrill [ Sat Feb 04, 2012 11:45 pm ] |
| Post subject: | Slipping clutch |
Hey guys I was driving off road today and I was in 4th and my clutch started slipping real bad but seemed to be fine in first and second It also was fine wen I was back on the road wat dose this mean ? Thanks guys |
| Author: | wolf_rt [ Sun Feb 05, 2012 12:14 am ] |
| Post subject: | Re: Slipping clutch |
If it is adjusted ok (ie. you press the clutch an inch or so before you feel it 'take up') it probably means you need a new clutch.... |
| Author: | zookdrill [ Sun Feb 05, 2012 12:25 am ] |
Oh ok how much is a new clutch ? |
| Author: | wolf_rt [ Sun Feb 05, 2012 1:33 am ] |
http://letmegooglethat.com/?q=suzuki+sierra+clutch |
| Author: | TryHard [ Sun Feb 05, 2012 11:53 pm ] |
Question What Tyre size are u running .. ? and are u running any reduction gears ? |
| Author: | zookdrill [ Mon Feb 06, 2012 5:57 am ] |
I'm running stock tyres and stock gearing As I said its fine on the road but as soon as I get past 2nd off road It starts slipping |
| Author: | want33s [ Mon Feb 06, 2012 7:50 am ] |
Replace the clutch, pressure plate, throwout and spigot bearing. Also get the flywheel machined. Total cost of clutch and machining should be under $300. |
| Author: | dawsey [ Mon Feb 06, 2012 4:34 pm ] |
wolf_rt wrote: I wish I had your I.T. savy...clever post!! |
