It is currently Tue Nov 03, 2026 9:19 am
Post Posted: Sun Feb 05, 2012 3:29 pm
Hi all, Im going to have a look at a vitara with the v6 4 speed auto H20a engine and would like to know some pros and cons.
I have done a search on what to look out for but couldnt find much.
Please mention anything you know about these engines or the car in general..especially fuel economy and motor performance etc..
This is the car,
http://www.carsales.com.au/private/deta ... 2&__N=1216 1247 1252 1282 4294962891 4294962890 903&distance=25&silo=Stock&Range=Price:Min,7500~1&sort=default
any advice would be greatly appreciated as i am not very well informed on suzi's.
Post Posted: Sun Feb 05, 2012 4:24 pm
TIMING CHAIN TENSIONER
This should have been done by now, but make sure the car is cold when you get there to look at it and it should be quiet on startup.
Any grinding type noise (like a noisy water pump/alternator) is likely to indicate the tensioner needs doing. This is a $1k+ job and would be cause for significant negotiation on price.
Other than that, it doesn't look to have been off road.
Just make sure everything works and there's no obvious oil leaks etc.
Post Posted: Sun Feb 05, 2012 7:30 pm
When are you planning to go look at it? I live only 15mins away and could come sus it out with you. Ive got a 98 Gv which is very similar mechanically.
Post Posted: Mon Feb 06, 2012 8:14 am
Why should have it been done by now??? It's only done 180,XXX kms
If there's no noise then there shouldn't be a need to replace it. Should it???
2002 SWB GV
Lifted and Locked
Post Posted: Mon Feb 06, 2012 8:41 am
The tensioners have a design fault and failure is extremely common. I believe the replacement part fixes the fault.
IMHO if it's quiet the tensioner will have been replaced.
Users browsing this forum: No registered users and 88 guests
