It is currently Sat Nov 14, 2026 5:20 am
Post Posted: Mon Feb 06, 2012 3:21 pm
After jacking up the front of my 1989 wt sierra and holding the wheel on the top and bottom movement is detected wuold this possibly be wheel bearings or am i on the wrong track.
smokey
Post Posted: Mon Feb 06, 2012 3:43 pm
leave the car on the ground, wiggle the wheel hard and listen/feel for a clunk. if you feel one get a mate to stand hard on the brakes and do it again. if it stops with the brakes on (or almost completely goes away) its a good indication its the bearings.
oil lights are like oven alarms, let u know its co
Post Posted: Mon Feb 06, 2012 3:49 pm
could be wheel bearings, could be king pin bearings, best way to check is get somebody to wobble while you look for which bit is moving and which isnt
Post Posted: Mon Feb 06, 2012 3:58 pm
Thanks for the info dosnt apear to have any movemement when on the ground.
Is there a post on replacing wheel bearings l could not find it using search function.
Regards Smokey
Post Posted: Mon Feb 06, 2012 4:03 pm
By applying the brakes you usually remove the bearings play and if it still wiggles it is usually kingpins. also jacking and slowly lowering and looking for movement in the kingpins.
Post Posted: Mon Feb 06, 2012 5:32 pm
Just checked again and movememt when brakes applied?
Smokey
Post Posted: Mon Feb 06, 2012 5:39 pm
If there is movement when brakes applied (i'm assuming front wheels) then i would be having a good look at king pins
Users browsing this forum: Google [Bot] and 106 guests
