It is currently Mon Sep 28, 2026 1:21 am
lesspostingmorewheeling
Post Posted: Mon Sep 29, 2008 6:50 pm
i'm trying to remove the door panel out of my sierra, i've removed the handle, door latch window winder an that strap thing bit i can't seem to get the panel off how can i get the panel off without damaging it?
Post Posted: Mon Sep 29, 2008 7:49 pm
Should just pop off? Its held by little press in clips, try getting the top, middle out first, and work to the edges. Flat head sxrew driver may help..
Post Posted: Mon Sep 29, 2008 7:54 pm
yeah i work from top back corner around. you have to be fairly forceful but not tair the studs out all the same
Post Posted: Mon Sep 29, 2008 8:56 pm
See if you can located the studs and lever right next to them.
Vehicle: MY2019 Jimny
Post Posted: Tue Sep 30, 2008 12:03 am
Yeah try and lever with something like a steel rule but stiffer... Maybe a stiff paint scraper...
Post Posted: Tue Sep 30, 2008 1:39 am
yep, just took mine off the other day to install central locking, i used a steel ruler, just slid it in next to each tab and pulled it outwards, they just pop out.
Post Posted: Tue Sep 30, 2008 1:45 am
you can buy a trim tool at super cheap that will slide around both side's of the clip
 Profile YIM
Users browsing this forum: Google [Bot] and 108 guests
