It is currently Sat Nov 14, 2026 4:50 am
Post Posted: Sat Feb 04, 2012 11:45 pm
Hey guys I was driving off road today and I was in 4th and my clutch started slipping real bad but seemed to be fine in first and second
It also was fine wen I was back on the road wat dose this mean ?
Thanks guys
Post Posted: Sun Feb 05, 2012 12:14 am
If it is adjusted ok (ie. you press the clutch an inch or so before you feel it 'take up') it probably means you need a new clutch....
Post Posted: Sun Feb 05, 2012 12:25 am
Oh ok how much is a new clutch ?
Post Posted: Sun Feb 05, 2012 1:33 am
http://letmegooglethat.com/?q=suzuki+sierra+clutch
Post Posted: Sun Feb 05, 2012 11:53 pm
Question What Tyre size are u running .. ? and are u running any reduction gears ?
Post Posted: Mon Feb 06, 2012 5:57 am
I'm running stock tyres and stock gearing
As I said its fine on the road but as soon as I get past 2nd off road
It starts slipping
Post Posted: Mon Feb 06, 2012 7:50 am
Replace the clutch, pressure plate, throwout and spigot bearing. Also get the flywheel machined.
Total cost of clutch and machining should be under $300.
Post Posted: Mon Feb 06, 2012 4:34 pm
wolf_rt wrote:
I wish I had your I.T. savy...clever post!!
Users browsing this forum: No registered users and 83 guests
