It is currently Fri Nov 06, 2026 10:36 am
Post Posted: Tue Feb 28, 2012 9:15 am
hey guys i may have picked up a fully rebuilt 4 age running rebuilt 4000k ago with recipts it comes with the hole car so just wondering what elce ill need for the conversion into my 84 suzuki sierra aka will i need a different clutch and gearbox tail shaft extensions engine mounts and shit tell me as much as ya can thx guys is it a hard job or easy... p.s matt
Post Posted: Tue Feb 28, 2012 12:28 pm
You need to make custom engine mounts gearbox mounts shorting jackshaft or move transfer back. you will also need a custom loom abd a few other things if you search you will find what you want
Post Posted: Tue Feb 28, 2012 1:51 pm
New or redone intake manifold (unless its already been made RWD)
Drivehafts lengethed (at around $150 each)
New engine mounts
New gearbox mounts
New transfer case mounts (as you will need to move the lot back, although you may get away with shortening the jackshaft
EFI wiring (make sure you get the full loom)
Fuel system, either in tank or out of tank set up
changing your cable clutch to a hydro clutch if you are using a t50 Ae71 gearbox
Just read your for sale thread, I think I will stop explaining the amount of work involved.
Users browsing this forum: Google [Bot] and 300 guests
