Page 1 of 1
[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Mike
lesspostingmorewheeling
Joined: Tue May 06, 2008 11:30 pm Posts: 2236 Location: Under Down Under
 Posted: Mon Sep 29, 2008 6:50 pm |
i'm trying to remove the door panel out of my sierra, i've removed the handle, door latch window winder an that strap thing bit i can't seem to get the panel off how can i get the panel off without damaging it?
kanejones
Joined: Tue Sep 16, 2008 11:30 pm Posts: 40 Location: frankston
 Posted: Mon Sep 29, 2008 7:49 pm |
Should just pop off? Its held by little press in clips, try getting the top, middle out first, and work to the edges. Flat head sxrew driver may help..
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Mon Sep 29, 2008 7:54 pm |
yeah i work from top back corner around. you have to be fairly forceful but not tair the studs out all the same
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Mon Sep 29, 2008 8:56 pm |
See if you can located the studs and lever right next to them.
_________________ SJ50.4.LYF
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Tue Sep 30, 2008 12:03 am |
Yeah try and lever with something like a steel rule but stiffer... Maybe a stiff paint scraper...
jbonevia
Joined: Thu Sep 11, 2008 11:30 pm Posts: 15 Location: Sydney
 Posted: Tue Sep 30, 2008 1:39 am |
yep, just took mine off the other day to install central locking, i used a steel ruler, just slid it in next to each tab and pulled it outwards, they just pop out.
jimbo_jones
Joined: Sat Jul 19, 2008 11:30 pm Posts: 4361 Location: gong
 Posted: Tue Sep 30, 2008 1:45 am |
you can buy a trim tool at super cheap that will slide around both side's of the clip
Page 1 of 1
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 129 guests
