It is currently Tue Oct 27, 2026 10:30 am
Post Posted: Wed Feb 15, 2012 2:31 pm
hi mates. my sierra is running rich. using heaps of fuel and now it fully fouled one plug and wasnt running on that cylinder.
do i need to rejet the carb or is there adjustments that can be made on it?
thanks mates
Post Posted: Sat Mar 03, 2012 6:10 pm
would not having the timing set properly effect fuel consumption? i never did it with timing light. its still at the point where ya put the distributer in to get it running.
Post Posted: Sat Mar 03, 2012 8:42 pm
If it starts easy and runs well enough to drive the timing can't be too far out. Look for another cause.
Have you checked the choke isn't stuck on?
Have you done a compression test?
Post Posted: Sat Mar 03, 2012 11:36 pm
i have done neither of them. which bits the choke on it?
Post Posted: Sun Mar 04, 2012 9:02 am
Jas, if the timing is well retarded, below 5° say, it would give indications of enriched mix, plus use excess fuel.
Comp, if you don't know what bit the choke is on, you need some help from a mate, or someone willing to give a hand. If you are bugerizing around with little knowledge it is easy to come unstuck and cause a sad dollar day.
Your in brizzy, lots of people around there, ask, someone will come.
Post Posted: Sun Mar 04, 2012 9:58 am
Possibly yes, but it would be difficult to start and the OP didn't mention that.
Post Posted: Sun Mar 04, 2012 12:02 pm
i know al ilttle bit about it. pulled motor and gearbox out and fitted new clutch and head and water pump and put it all back in and installed carby and fuel pump by myself
starts perfect and runs perfect. does all the hills and roots chix. just used lots of fuel and fouls the plugs
might compression test it. its been rebuilt sometime, apparently about 50 000kms. saw the oversize pistons when i pulled it down.
Post Posted: Sun Mar 04, 2012 12:57 pm
The choke is the flap that blocks the primary barrel at the top of the carby.
It should only sit horizontal when the engine is COLD.
As the engine warms up, the water warms the wax pellet and makes it expand pushing the choke open.
You may need to wire the choke open.
Post Posted: Sun Mar 04, 2012 1:04 pm
oh yep ok. that was done on my last carby also. will have a look at this one. thanks
Users browsing this forum: Google [Bot] and 225 guests
