| 1.3 sierra running rich. rejet or what? http://auszookers.com/forum/viewtopic.php?f=5&t=30498 |
| Author: | CompTruck [ Wed Feb 15, 2012 2:31 pm ] |
| Post subject: | 1.3 sierra running rich. rejet or what? |
hi mates. my sierra is running rich. using heaps of fuel and now it fully fouled one plug and wasnt running on that cylinder. do i need to rejet the carb or is there adjustments that can be made on it? thanks mates |
| Author: | CompTruck [ Sat Mar 03, 2012 6:10 pm ] |
| Post subject: | Re: 1.3 sierra running rich. rejet or what? |
would not having the timing set properly effect fuel consumption? i never did it with timing light. its still at the point where ya put the distributer in to get it running. |
| Author: | want33s [ Sat Mar 03, 2012 8:42 pm ] |
If it starts easy and runs well enough to drive the timing can't be too far out. Look for another cause. Have you checked the choke isn't stuck on? Have you done a compression test? |
| Author: | CompTruck [ Sat Mar 03, 2012 11:36 pm ] |
i have done neither of them. which bits the choke on it? |
| Author: | SuziBlu [ Sun Mar 04, 2012 9:02 am ] |
Jas, if the timing is well retarded, below 5° say, it would give indications of enriched mix, plus use excess fuel. Comp, if you don't know what bit the choke is on, you need some help from a mate, or someone willing to give a hand. If you are bugerizing around with little knowledge it is easy to come unstuck and cause a sad dollar day. Your in brizzy, lots of people around there, ask, someone will come. |
| Author: | want33s [ Sun Mar 04, 2012 9:58 am ] |
SuziBlu wrote: Jas, if the timing is well retarded, below 5° say, it would give indications of enriched mix, plus use excess fuel. Possibly yes, but it would be difficult to start and the OP didn't mention that. |
| Author: | CompTruck [ Sun Mar 04, 2012 12:02 pm ] |
i know al ilttle bit about it. pulled motor and gearbox out and fitted new clutch and head and water pump and put it all back in and installed carby and fuel pump by myself starts perfect and runs perfect. does all the hills and roots chix. just used lots of fuel and fouls the plugs might compression test it. its been rebuilt sometime, apparently about 50 000kms. saw the oversize pistons when i pulled it down. |
| Author: | want33s [ Sun Mar 04, 2012 12:57 pm ] |
CompTruck wrote: i have done neither of them. which bits the choke on it? The choke is the flap that blocks the primary barrel at the top of the carby. It should only sit horizontal when the engine is COLD. As the engine warms up, the water warms the wax pellet and makes it expand pushing the choke open. You may need to wire the choke open. |
| Author: | CompTruck [ Sun Mar 04, 2012 1:04 pm ] |
oh yep ok. that was done on my last carby also. will have a look at this one. thanks |
