It is currently Thu Aug 06, 2026 1:51 pm
Post Posted: Wed Feb 22, 2012 6:59 am
will the normal g16a extractors clear the chassis,engine mount in a W/T sierra.
will the 1.3 inlet manifold match up to the g16a head.
thanks rorie.
Post Posted: Wed Feb 22, 2012 7:43 am
Unsure about the g16 extractors missing engine mount, but the g13 extractors and manifolds will bolt up.
Post Posted: Wed Feb 22, 2012 3:05 pm
Just need to make a longer peice on the exhaust so it clears the body under the car inlet I have no idea just run the g16a with the Sierra top hat and modify to fit
Post Posted: Wed Feb 22, 2012 5:20 pm
Do you mean Carby/8V G16? There are EFI 16V G16A's too - I have one.
If you mean carby/8V vitara, yes, the extractors and inlet manifold will bolt up. There should be no reason to modify the extractors - the deck height is slightly taller on the G16 but the exhaust should still clear everything - out's only about 13mm taller
Post Posted: Wed Feb 22, 2012 7:37 pm
yeah i meant carby 16a, i thought only 16b were 16 valve..
my original 13ba has a webber and modified inlet manifold + near new extractors so was hoping to bolt them straite on
to the 16a..
i now have the engine here and gaskets match up so should be all good.
thanks steve
Post Posted: Wed Feb 22, 2012 7:41 pm
zuki also has 2" body lift so i guess underbody clearence should be sweet.
Post Posted: Wed Feb 22, 2012 7:42 pm
to the 16a..
thanks steve
sierra inlet manifold wont fit carby 16a as the fuel pump gets in the way.
Post Posted: Wed Feb 22, 2012 7:55 pm
? Really
I know the Vitara fuel pump is different, but didn't think the bolt pattern for the manifold was different. Could the sierra manifold be ground to clear?
Steve
Post Posted: Wed Feb 22, 2012 9:07 pm
? Really
Steve
possibly however i just put the vit manifold back on and put the sierra carby on it.
the G16 i had originally had a poxy falcon Weber on it and that was going no where near my car :)
Post Posted: Fri Feb 24, 2012 3:16 pm
? Really
Steve
all up and runin now,,
yes the 1.3 manifold hits the fuel pump, so a little grinder attack and it slips straite on..
not much but the 1.6 manifold ports are actually a few mill biger than the 1.3 manifold..
i had allready ported out where the carby bolts on to the manifold to suit the webber ( it makes quite a difference)
as i tried it both ways.
1.6,webber , extractors, 2'' exhaust.. deffinatly has more torque now than the 1.3. but doesnt seem to rev as hard (cam next)
Post Posted: Fri Feb 24, 2012 4:51 pm
Which is the effect of 13mm more stroke - they won't rev as hard.
Post Posted: Sun Feb 26, 2012 3:31 am
Whats the highest rev range you would take a 16a to?
Post Posted: Sun Feb 26, 2012 12:32 pm
1.6 With webber and exhaust, mine has torque straite away but only likes to rev to 5500rpm
rebuilt 1.3ba with webber,cam, exhaust. puck all torque but happily reved to 7000rpm
Post Posted: Sun Feb 26, 2012 1:00 pm
Clutch in, next gear, clutch out.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 921 guests
