It is currently Thu Aug 06, 2026 3:31 pm
Vehicle: 02 Suzuki Jimny
Post Posted: Thu Feb 23, 2012 11:32 am
Hey Guys,
Tryin to get my suzi through a rwc... and they've pinged me on the fact that 'Hot air can't be directed at the windscreen'.
The climate controls are all buggard and it's basically on or off, no control over the direction.
Can anyone provide me with information as to how I can get back behind the dash to have a look about fixing it?
Cheers.
TF
Post Posted: Thu Feb 23, 2012 12:08 pm
The air direction vents are controlled by cables.
I would be getting under the dash to find all cables to see if they are all complete and in the right position. Should be able to see them without removing anything.
Post Posted: Thu Feb 23, 2012 12:12 pm
I think last time I looked in the manual the control for the direction of airflow was on the bottom right of the heater jsut above where your left foot would sit, look under there while moving the control around and youll probably figure it out
Vehicle: 4wd
Post Posted: Thu Feb 23, 2012 1:24 pm
x2
There is a cable that clips into the lever that is visible. It's easy for this cable to pop out.
Watch out or you'll get sued.
Post Posted: Thu Feb 23, 2012 1:39 pm
So these cables can be accessed relatively easliy can they?
TF
Vehicle: 4wd
Post Posted: Thu Feb 23, 2012 1:40 pm
Yeah just put your head down in the foot well and it will just about poke your eye out.
Post Posted: Thu Feb 23, 2012 2:12 pm
I have this problem with my sierra, I had a look and the spotweld that clamps the cable has broken. What would be the best way to fix it?
Vehicle: 4wd
Post Posted: Thu Feb 23, 2012 2:19 pm
On the heater tap end?
Post Posted: Thu Feb 23, 2012 10:46 pm
Talking Jimny here. Bit more plastic :)
Post Posted: Fri Feb 24, 2012 3:20 am
Unfortunately not. It's behind the controls on the dash. Means I can't defrost my windscreen :x
Post Posted: Fri Feb 24, 2012 8:26 am
Move somewhere more tropical.
Post Posted: Sat Feb 25, 2012 10:33 pm
Well i pulled the dash apart today to have a look at it. First step was to look in the footwell but unfortunately the problem wasn't there.
Pulled the lever unit out and sure enough the cable for the Fresh air and Cabin air had just popped out, so I put that back in and put a zip tie around it.
The lever that directed the route of the air had also come out but the plastic keepers that hold the end in place were wrecked to buggery!. So i put it back in as best I good and put a ziptie around it to hold it steady and glued the gold end into place. I figured it's the best I could do....
I shoulda taken photos, but i'm just glad that it's all fixed up. I'll be using those levers with care from now on.
TF
Users browsing this forum: Google [Bot] and 897 guests
