It is currently Mon Sep 28, 2026 12:36 pm
lesspostingmorewheeling
Post Posted: Fri Oct 03, 2008 12:20 am
i got a couple gauges laying around and i'm wondering if i can use them on my zook
i've got an aftermarket speedo and i'm wondering if i can use it to correct for my 31s
also i got a cylinder head temp gauge i know i don't really need but would there be any way i could use it?
Post Posted: Fri Oct 03, 2008 12:27 am
twin overhead speedos sounds cool
cylinder head temp could be useful I guess, dont they mount under a spark plug?
Post Posted: Fri Oct 03, 2008 12:32 am
well i got a speedo and a matching tacho but i have no idea how to hook up the speedo :roll:
i have to see if i can find an sender for the cylinder head temp gauge
Post Posted: Fri Oct 03, 2008 1:23 am
if you want to correct your speedo with 31's just get the reciever for the speedometer calibrated to the gearing ratios for your car. A mate was quoted about $40 to do it up here a while a go
Post Posted: Fri Oct 03, 2008 1:25 am
where would i go to get that done?
Post Posted: Fri Oct 03, 2008 1:28 am
gear box specialist? engine reconditioner? if not mechanics might be able to give you someone who does it
Post Posted: Fri Oct 03, 2008 3:00 pm
There are places that deal specifically with fixing speedos. Google it.
Is the aftermarket speedo electronic or mechanical? If it's electronic then you will have to get an adaptor to fit the gearbox. If it's mechanical then you may need an adaptor for the back of the speedo head.
Post Posted: Fri Oct 03, 2008 8:26 pm
its an electronic one i'm pretty sure it was gonna be used on a bug but that never happened i'll have to look to see if i have a sender anywhere
Users browsing this forum: Google Adsense [Bot] and 87 guests
