| checked plate armor http://auszookers.com/forum/viewtopic.php?f=5&t=3074 |
| Author: | tonka_zook [ Fri Oct 03, 2008 2:00 am ] |
| Post subject: | checked plate armor |
hey i need to make up some armor for my zook n would like to know if any one as made some up for there zook |
| Author: | Zook_Fan [ Fri Oct 03, 2008 2:03 am ] |
| Post subject: | Re: checked plate armor |
where do you want to put it? what sort of armour? and where have you found in town to get cheapish checker plate? |
| Author: | tonka_zook [ Fri Oct 03, 2008 2:09 am ] |
i want it on the back corners. haven't found any cheap checker plate but i got a old checker plate tool boxs i got give. i'll just make it out of that |
| Author: | Mike [ Fri Oct 03, 2008 2:14 am ] |
checkerplate corners that you can buy have a section cut out of the middle and welded up i think its to make it fit the corner better you might have to do something similar |
| Author: | Zook_Fan [ Fri Oct 03, 2008 2:15 am ] |
which would be hard to do well unless you are handy with a tig |
| Author: | Mike [ Fri Oct 03, 2008 2:18 am ] |
you can mig weld alloy? |
| Author: | Zook_Fan [ Fri Oct 03, 2008 3:03 am ] |
yeah but for looks purposes tig would be much better |
| Author: | tonka_zook [ Fri Oct 03, 2008 2:34 pm ] |
how hard is to weld |
| Author: | ODA1 [ Fri Oct 03, 2008 3:06 pm ] |
maybe you can see opposite lock and order some pre made corners from Pirahna Off Road, i think they were $40. ( memory blury!! ) |
| Author: | Scrawny [ Fri Oct 03, 2008 3:11 pm ] |
Mike wrote: you can mig weld alloy?
You sure can. Mig is the butchers welder though. Tig is the artisans welder |
| Author: | Pubic [ Fri Oct 03, 2008 4:13 pm ] |
any mig over about 200 amps can weld ally. tigs need to be ac/dc to do it. ally is great fun to weld seeing that the inside of the alluminium will melt before the outer layer, thats what makes it harder to weld. |
| Author: | Mike [ Fri Oct 03, 2008 8:33 pm ] |
ODA1 wrote: maybe you can see opposite lock and order some pre made corners from Pirahna Off Road, i think they were $40. ( memory blury!! )
i'm pretty sure the pirahna ones are around $130 a pair |
| Author: | Fatzook [ Sat Oct 04, 2008 4:02 pm ] |
ScrawnC wrote: Mike wrote: you can mig weld alloy? You sure can. Mig is the butchers welder though. Tig is the artisans welder Thats true to a piont but for most companies that produce large amounts of fabricated aluminium products the TIG is too costly and time consuming. Most will use a Pulse MIG, which is in many circles argued to be better than TIG on ally anyway. I personally don't have one, but I do want one. Pete |
| Author: | tonka_zook [ Sun Oct 05, 2008 1:17 am ] |
i'm not welding any thing i just want to make some checkerplate corners |
| Author: | Zook_Fan [ Sun Oct 05, 2008 1:27 am ] |
then cut and roll them how hard is it? Yes they have been done before heaps of times here is one from outers http://www.outerlimits4x4.com/ftopic141 ... sc-150.php she isnt bad either |
| Author: | Mike [ Sun Oct 05, 2008 1:33 am ] |
Zook_Fan wrote: she isnt bad either
isn't she a bit young for you? those ones are the bought welded ones from somewhere like snakeracing, pirahna etc. |
| Author: | Zook_Fan [ Sun Oct 05, 2008 1:37 am ] |
not really she is like 1 year younger then me |
