It is currently Thu Oct 01, 2026 1:49 am
Vehicle: '92 Sierra
Post Posted: Fri Oct 03, 2008 6:35 pm
Ok this seems like a completely dumb noob question but where do you buy crush sleeves in varying sizes. I've thought they'd be useful in chassis mounts, shock mounts etc. in the past but I've never really had any idea where to get em so I've made work arounds.
Can someone put me out of my misery?
Post Posted: Fri Oct 03, 2008 6:48 pm
I didn't think you could get them as on off the shelf kinda item, but would be quite happy to be wrong!!!
Vehicle: '92 Sierra
Post Posted: Fri Oct 03, 2008 6:53 pm
Not so much off the shelf to length. I mean lengths of "sleeve" in different diameters and wall thickness. I know technically this is just pipe but your regular steel supply doesnt sell steel pipe small enough for shock eyes etc.
Post Posted: Fri Oct 03, 2008 7:18 pm
when you get down into 8 and 10nb its pretty small
plumbing supplies will have 200mm bits
Post Posted: Fri Oct 03, 2008 7:19 pm
I think even hollow bar is too big.
Vehicle: 75 Cruiser
Post Posted: Fri Oct 03, 2008 7:29 pm
I have been making my own.
I use the Sierra B Pillar support brackets. Suits most size bolts. I cut to the required length. All the ones i have done are for smaller bolts, so i cut a slit down the tube lengthways, then hammer/work the joins together slowly hammering on each side to keep the tube round and not egg shape.
Vehicle: '92 Sierra
Post Posted: Fri Oct 03, 2008 7:41 pm
Lol I think I need that bit. Might buy a couple of donor zooks :lol: I thought of plumbing supplies but then thought they probably used copper. I'll actually have to go looking by the sounds of it. Thanks guys.
Post Posted: Fri Oct 03, 2008 7:44 pm
no you can buy small PIPE used for water feeds in buildings over long straight runs
and all sorts of useful flanges and stuff too
Vehicle: LJ20 LJ50
Post Posted: Fri Oct 03, 2008 8:01 pm
We always used just small 12 mm ID steel pipe so we could used 12mm HT bolts
Lots of small pipe will work and if it is the right outside diameter you can always run a drill down the centre to make it a little larger if you are using thick wall pipe
Also if you really need somethin exactly right then just get them made. Not that expensive. Find an engineering shop and ask if they could turn up some sleeves for you out of scrap. Most guys will do it for a 6 pack
Camels have nice toes
Post Posted: Sun Oct 05, 2008 1:25 am
HYDRAULIC PIPE you can get it in all sizes down to 1/4" and it has a heavy enough wall to work as crush tube.
Go to enzed with the bolt and ask if they have a bit of offcut that will suit. if they dont they usually sell by the amount you want.
Post Posted: Sun Oct 12, 2008 5:56 pm
x2 on enzed. thats where I have bought tube for my crush sleeves on front bar.
Visit The 4wd Shop
Users browsing this forum: Google [Bot] and 162 guests
