It is currently Mon Nov 02, 2026 2:55 pm
Vehicle: sierra, 31's, 6.5's
Post Posted: Thu Mar 01, 2012 6:02 am
I am in th process of lookin for a new carby, I am trying to look for a simpler one, after a bit of research I have found the Toyota corolla 4k carby to be the best match, is it a straight bolt in or do i need an adaption plate??
By the way it is for a 1994 Sierra
don't follow me, you won't make it
Post Posted: Thu Mar 01, 2012 7:50 am
Sierra carby is held down with four bolts about 120mm long that go through the carby to the inlet manifold.
3-4-5K Corolla carby has the same 4 bolt pattern but it uses short studs in the manifold and nuts to hold carby.
If you are going to fit a rolla carby then grab the studs from the inlet manifold or at least measure one so you can buy some.
The accel linkage is very similar.
You will need to get fancy with the airhat if you want to keep the Sierra aircleaner.
Post Posted: Thu Mar 01, 2012 8:18 am
http://www.acksfaq.com/toycarbinstall.htm
Users browsing this forum: No registered users and 76 guests
