It is currently Mon Aug 03, 2026 4:06 am
Post Posted: Sun Mar 04, 2012 8:59 am
Hey guys,
last time i was home i discovered a leak in my T-case fwd prop shaft seal. My seal kit arrived the other day from bigjimny and i was wondering what size socket is required to get the flanges off so i can get the seals out?
at work atm so im thinking i may need to borrow a big socket.
also, any other pointers on doing this job? never tackled it before, figured it cant be that hard... :?
MY BUILD THREAD HERE!!!!!
Post Posted: Sun Mar 04, 2012 10:07 am
It isn't a huge job.
If you can't undo the flange nut in the car you can remove the whole front output housing and put it in a vise.
From memory the nuts are 26mm but I'm prob wrong. Pretty sure I use a 1 1/16" socket which works out to be 27mm.
Sorry not much help.
Post Posted: Sun Mar 04, 2012 10:12 am
27mm from memory, rattle gun that bad boy off. Helps if it is in low range at the time.
Post Posted: Sun Mar 04, 2012 10:59 am
Yep, 27mm.
Post Posted: Sun Mar 04, 2012 4:12 pm
cool thanks lads. ill probably drop the whole case out so i can give it a bit of a tidy up and clean, and fit a breather to it! (so much water came out when i drowned it last, coulda been the seal though) plus itll make it a bit easier to do the job.
Post Posted: Fri Mar 23, 2012 6:26 pm
What did you have to change the seal? I need to do this too.
SS
Vehicle: Coily "Ute"
Post Posted: Mon Jul 16, 2012 11:47 am
sorry to bump up a old thread but I also need to do this.
I've done anything like this before, any tips? is there a guide somewhere on the forum? I have been looking
Post Posted: Mon Jul 16, 2012 12:37 pm
I ended up doing a case swap (different reason), But i did do the rebuild on the new case last week including changing seals. should be achievable on the car, with a bit of dicking around, personally id drop it and do on the bench.... only cos i can get the case out in about 20mins now.
your only hard part will be getting the flange nuts and possibly the flanges themselves off. i had to use a rattlegun and a bearing puller on one of my flanges. I also snapped a screwdriver prying the little lock tabs out of the nut too.
which shaft is leaking? if its the front output shaft, probably easier taking the front housing off if you were doing in-situ. If you look at step 70 here
http://www.trail-gear.com/pdf/suzuk-tcase.pdf
anyway dude, it really isnt hard. i was worried itd be a mission but its a piece of piss. Take your time and think about what your doin and youll be right. and if its too hard under the car, just pull it out and do on the bench.
Vehicle: Drover pickup turk
Post Posted: Mon Jul 16, 2012 6:06 pm
Here is what I did to get the flanges nuts off. Held the jig in the vice and went to town with a crack bar.
I like the tuna here
Users browsing this forum: No registered users and 295 guests
