It is currently Wed Oct 28, 2026 10:46 am
Post Posted: Sun Mar 04, 2012 7:39 pm
This has been my third trip in my 09 GV and the ESP is really pissing me off.
Is there a way to disconnect it completely whilst in 4WD?
I know it gets turned off in 4L but the 35km limit in 4H is a pain.
I was on the beach today in 4H doing about 50K and the stupid ESP kept cutting in and trying to brake the slipping wheels.
I made it through without a problem but the strange noise and braking is disconcerting.
My cousin has a Kia Sorrento (about the same year) and his turns off as soon as he goes into any 4WD mode.
I can't understand why the GV turns it off after 35K and the Kia doesn't.
Can anyone shed some light on this for me as if I am stuck with this, I may need to look at the same Kia
I'm not sure if this has been covered but I did do a search and came up with not much... :(
Post Posted: Sun Mar 04, 2012 7:42 pm
Kia isnt a 4wd
sounds like the ESP was stopping the swaying and general sliding around you get on the beach, I cant see why you would worry about it
Post Posted: Sun Mar 04, 2012 7:50 pm
Kia isnt a 4wd
The Kia has 4H & 4L and with a lift kit so I consider it a capable as mine.
Only difference is his runs on a soft beach without a problem and mine has an ESP that seems to want to stop me in my tracks.
If it's not braking the slipping tyres and making me feel uncomfortable, it's kicking in when I'm trying to concentrate and dropping all my power to a crawl.
It is annoying!!
Post Posted: Sun Mar 04, 2012 7:51 pm
yeah its shit mine does it to especially in rutted sand when u want to go faster than 35
just stay on the gas and put up with it.
i asked about this on http://www.newgrandvitara.net/ and apparently theres fuck all ucan do cept pull the abs fuse ???
Post Posted: Sun Mar 04, 2012 7:53 pm
can you wire a switch to the abs fuse so its easy to flick off/on? would stop you being lazy and not putting the fuse back in when you got back on the road =)
Post Posted: Sun Mar 04, 2012 7:58 pm
I see it as a serious flaw because it starts to fight against what I am trying to do.
It basically means all my offroading has to be in 4L as the 4H mode cannot be trusted..
If any one knows how to kill the ESP fuse, that would be great.
I still think it's a stupid over sight by Suzuki as it's something I shouldn't have to do!!!
Post Posted: Sun Mar 04, 2012 8:03 pm
whats the esp off button do?
Post Posted: Sun Mar 04, 2012 8:09 pm
In 4H turns it off until it hits 35k/hr.
The annoying thing is that it re-activates it when you hit that speed then when you are busy doing other things like "offroading"....getting out of a soft patch of sand and don't realise it has done it, the ESP takes over and all of a sudden it starts braking wheels that are slipping and cut engine power so you have your foot to the floor and it's just trickling over.....
I AM PISSED OFF OVER THIS TO SAY THE LEAST.........
Vehicle: 4wd
Post Posted: Sun Mar 04, 2012 8:14 pm
It's a family car or a soft 4wd. I had a car with it and never again. :)
Watch out or you'll get sued.
Post Posted: Sun Mar 04, 2012 8:24 pm
Yes it is a soft 4wd but it handled the soft beach beautifully....that is if it wasn't for the ESP trying to take over!!
If there is a way to just kill it whilst I'm offroad, that will have to do.
Apart from that, it is a fantastic car!!
I think I'm going to go and have a chat with the boys from suzieworld to fix this annoyance....
What ever happened to a transfer case lever and getting out and locking the hubs in....sheeeeez :cry:
Post Posted: Sun Mar 04, 2012 8:32 pm
when u pull the fuse apparently the dash lights up like a xmas tree with all sorts of flashing lights.
keep in mind this is 2nd hand info here not first hand by myself
Post Posted: Sun Mar 04, 2012 8:38 pm
maybe ask here
http://newgrandvitara.net/modules/newbb/
Post Posted: Sun Mar 04, 2012 9:35 pm
already did, not much help
Post Posted: Sun Mar 04, 2012 10:23 pm
pull the fuse and see what happens. then ya can tell us if anything blew up :D
i dont drive on sand so it hasn't been a issue
Post Posted: Mon Mar 05, 2012 3:27 am
Can't u just drive it on he beach in low range
There low is not that deep so u should be able to get to 60 which is all u need on the beach
Post Posted: Mon Mar 05, 2012 5:51 am
forbee4 wrote:
stockman wrote:
I had a car with it (ESP) and never again. :)
Whilst I can imagine that ESP is frustrating on the beach, It is going to be increasingly difficult to override these systems.
However, the more cars that run ESP, the better it will become. Well tuned ESP should be barely noticeable. It's often not at the moment.
As ABS technology continues to improve, so the speed and effectiveness of traction control and ESP improve. I've had the traction/ESP light fire on my current car a couple eof times but I haven't had any idea what it was "fixing" - in that I couldn't detect the intervention.
Interestingly, my current road car has two ESP settings - "on" and "traction enhanced" which loosens ESP allowing some wheelslip.
I haven't tried to feel the difference between the modes.
I would try pulling the ABS fuse and then, If that's effective, investigate a switch. I do think sand might be the worst case scenario for ESP.
Post Posted: Mon Mar 05, 2012 7:38 am
sand and high speed gravel can be quite dangerous when mid corner esp takes all the power away
or brakes one of the front or rear tyres. the gravel was really bad it nearly tried to put me into a tree or ditch a few times
this was doing around 80-90 i found it to be more of a saftey thing than on the sand
where its just annoying
Post Posted: Mon Mar 05, 2012 8:20 am
I'm not trying to be a wanker here, but is it really "dangerous" or just "unexpected"?
Whilst it's unnerving to feel a car do something contrary to what you'd expect, I'm not sure it's necessarily more dangerous than without ESP.
However, I am quite sure it will work hard to counter what many of us consider "normal" driving on dirt - i.e set the car up and drift it around the corner. If you drive this way I'm sure ESP will be doing all sorts of things to correct the car. My guess is that a different driving style will be required to get the best out of ESP on dirt.
PS whilst I don't own a GV, I have driven cars with ESP on wet roads
Post Posted: Mon Mar 05, 2012 11:03 am
Dirt roads here are used often so peoLe that drift around corners become statistics quite quickly.
Post Posted: Mon Mar 05, 2012 11:11 am
Have you contacted Suzuki about it? Even if they have no answers for you if enough people complain about it then it might be something they look into on the next upgrade.
Vehicle: 08 jimny all stock atm
Post Posted: Mon Mar 05, 2012 12:39 pm
my view on esp is its dangerous
i have been drifting for 6 years now and a friend wanted me to have a go at his new ve clubsport in the wet, has i came to a right hander i gave it the flick and esp took over and lined the car up with the curb / tree lucky it was in the wet so entry speed was low and esp turned off just in time for me to have a second go a trying to turn
now i know i was doing the wrong thing but getting the rear our in the wet when a car has 300kw is gonna happen one day to every one and the last thing i want is the esp to take over ......
driver training has gotta be a better option than esp imo
Post Posted: Mon Mar 05, 2012 1:49 pm
how about not doing that shit where my family might be coming the other way
Post Posted: Mon Mar 05, 2012 2:07 pm
As an opposite, A friend has a turbo focus says watch this, turns into a long tight corner, 270 degree exit ramp, concrete both sides, plants his foot and turns, once we get to the point where we are too fast to keep traction it starts doing its thing and we go around fine, he just held the wheel, no correcting or stuffing around
That is what its sposed to do, if you are doing what you think is normal driving and its pulling you back perhaps you need to rethink your driving style
Vehicle: SJ80, SE416
Post Posted: Mon Mar 05, 2012 2:28 pm
Maybe so, but having the rear end slide out in the wet is rarely going to happen by accident if the driver has half a brain...
IMO the only reason ESP has become mandatory is because too many stupid people have tried their awesome 'drifting' skillz on public roads, caused crashes, blamed the road conditions instead of their own actions and now because of crash statistics goverment bodies have been forced to take action and legislate against your awesome 'drifting' practices by making ESP mandatory reducing your ability to get sideways. From my experience with ESP and Commodores - on tarmac you need to be driving in a fashion far from ordinary before the ESP will fire - and it does work when a sudden slide catches you off guard - such as dropping a wheel onto a gravel shoulder while cornering.
From my days driving a jap import I also found throttle control much easier with more power available - it was easier to back off and find the sweet spot instead with a more responsive/powerful engine so Jordan, your 300kW argument just doesn't add up.
Post Posted: Mon Mar 05, 2012 3:06 pm
the issue would be though, that the people who like drifting corners etc are going to pull their ABS fuses and then not only will they be missing ESP, they'll also have no ABS! lol
Post Posted: Mon Mar 05, 2012 4:31 pm
kinda regretting share my thoughts on esp lol
guess my point was missed esp seems to want to straighten the car , if making the turn is the only option esp isnt going to help imo
reubs
i thought esp came about due to people freaking out when somthing happens on a straight road, they swing the steering one way and try to swing it back and there on there way to a tree ?
my comment was if you buy a v8 with 300kw one day the power will catch you out in the wet ? im not shore how that doesnt add up :?
Post Posted: Mon Mar 05, 2012 4:51 pm
Jordan, I only want to disable it when I'm offroad.
Post Posted: Mon Mar 05, 2012 5:12 pm
Does anyone know how to attach a photo?
Mine comes up with "Invalid File Format"!!
Post Posted: Mon Mar 05, 2012 6:11 pm
jordan wrote:
reubs
ESP is equally as valid on twisting roads - the only times I've felt it fire.
Also, I've owned about 200kW in a roughly 1300kg RWD vehicle and never had a problem with 'lots of power and wet roads'. Maybe I have some awesome skills of being able to control the throttle or maybe I had some magical grippy tyres.
Stupid 'drifters' are the reason my insurance was $2000 per annum with a $1000 special vehicle excess on top of the standard excesses...
Post Posted: Mon Mar 05, 2012 6:28 pm
As mentioned in an earlier post...4L will disable the ESP. Otherwise air down to 18psi and avoid the softer section of the beach.
Users browsing this forum: No registered users and 365 guests
