It is currently Tue Nov 03, 2026 1:40 am
Post Posted: Mon Mar 05, 2012 3:39 pm
just question on tyres
went to a tyre place and wanted to put 235/75r16 Nangkang Mudstars on
they pretty much said no.
whats the bigeest tyre i can go,
or what have Previous GV owners gone? would like muddies
have a 2 1/5 inch lift
If in doubt power out!
Post Posted: Mon Mar 05, 2012 3:43 pm
Go somewhere else.
Post Posted: Mon Mar 05, 2012 3:45 pm
I have 225/75r16's with just over 2 inch lift and they only just fit
Post Posted: Mon Mar 05, 2012 3:46 pm
From what I have read...
225/70/16 fit with zero rubbing (Macdaddy runs them)
225/75/16 fit but may need a *tiny* bit of massaging
245/70/16 fit again with a bit of massaging (pretty sure built4thrashing and gdixon are both running this size)
Any bigger than that (245/75/16, 265/70/16, 235/85/16 etc) and you will have to get creative with a hammer/grinder.
235/75/16 only measures ~29.8 inches overall diameter, so I can't imagine they would need too much work to get them to fit.
Moses' SQ625 GV Pig
Post Posted: Mon Mar 05, 2012 5:59 pm
I run 245/75/16. They fit with a huge ammount of effort and cutting of the inner plastic in the arches.
They will not fit if you still have the stock front bumper
Post Posted: Mon Mar 05, 2012 6:06 pm
yeah just the tyre guy was goin on about the legal side of things, then said i'd be changing the gearbox every 3 months?
Post Posted: Mon Mar 05, 2012 6:07 pm
Tyre diameters for those interested
235/60/16 = 688mm
225/70/16 = 721mm
225/75/16 = 743mm
245/70/16 = 749mm
255/70/16 = 763mm
245/75/16 = 773mm
Vehicle: 2002 GV V6 and self shifter
Post Posted: Wed Mar 07, 2012 11:50 pm
As far as I understand the new rules (according to VSB14) for increase in tyre size without the need for an engineers cert, have a look at the attached spreadsheet and filter for tyre diameter difference (column I) between -26 and 50
I've only used 16 inch rims and know not if they will physically fit.
tyres.xls
Users browsing this forum: No registered users and 629 guests
