http://auszookers.com/forum/
2000 Suzuki Gv
http://auszookers.com/forum/viewtopic.php?f=5&t=30948
Author:  ando_zook94 [ Mon Mar 05, 2012 3:39 pm ]
Post subject:  2000 Suzuki Gv
just question on tyres
went to a tyre place and wanted to put 235/75r16 Nangkang Mudstars on
they pretty much said no.
whats the bigeest tyre i can go,
or what have Previous GV owners gone? would like muddies
have a 2 1/5 inch lift
Author:  Fatzook [ Mon Mar 05, 2012 3:43 pm ]
Post subject:  Re: 2000 Suzuki Gv
Go somewhere else.
Author:  Joe [ Mon Mar 05, 2012 3:45 pm ]
I have 225/75r16's with just over 2 inch lift and they only just fit
Author:  ninjamoses [ Mon Mar 05, 2012 3:46 pm ]
From what I have read...
225/70/16 fit with zero rubbing (Macdaddy runs them)
225/75/16 fit but may need a *tiny* bit of massaging
245/70/16 fit again with a bit of massaging (pretty sure built4thrashing and gdixon are both running this size)
Any bigger than that (245/75/16, 265/70/16, 235/85/16 etc) and you will have to get creative with a hammer/grinder.
235/75/16 only measures ~29.8 inches overall diameter, so I can't imagine they would need too much work to get them to fit.
Author:  Built4thrashing [ Mon Mar 05, 2012 5:59 pm ]
I run 245/75/16. They fit with a huge ammount of effort and cutting of the inner plastic in the arches.
They will not fit if you still have the stock front bumper
Author:  ando_zook94 [ Mon Mar 05, 2012 6:06 pm ]
yeah just the tyre guy was goin on about the legal side of things, then said i'd be changing the gearbox every 3 months?
Author:  Built4thrashing [ Mon Mar 05, 2012 6:07 pm ]
Tyre diameters for those interested
235/60/16 = 688mm
225/70/16 = 721mm
225/75/16 = 743mm
245/70/16 = 749mm
255/70/16 = 763mm
245/75/16 = 773mm
Author:  dhula [ Wed Mar 07, 2012 11:50 pm ]
As far as I understand the new rules (according to VSB14) for increase in tyre size without the need for an engineers cert, have a look at the attached spreadsheet and filter for tyre diameter difference (column I) between -26 and 50
I've only used 16 inch rims and know not if they will physically fit.
tyres.xls
