| Rear hub bolts http://auszookers.com/forum/viewtopic.php?f=5&t=3095 |
| Author: | Damo [ Sun Oct 05, 2008 8:59 pm ] |
| Post subject: | Rear hub bolts |
What size are the bolts that hold drum on to the axle shaft? M12? |
| Author: | royce [ Sun Oct 05, 2008 9:24 pm ] |
| Post subject: | Re: Rear hub bolts |
the thread IIRC is M12 FINE the studs in the axle, no idea how long they are but at a guess 35mm? |
| Author: | Damo [ Sun Oct 05, 2008 9:28 pm ] |
royce wrote: the thread IIRC is M12 FINE
the studs in the axle, no idea how long they are but at a guess 35mm? Yeah they would be about that. Has anyone had the nuts on these fail before? Prolly just idiots doing them up too right i'd say. |
| Author: | TZAR [ Sun Oct 05, 2008 9:44 pm ] |
Damo wrote: royce wrote: the thread IIRC is M12 FINE the studs in the axle, no idea how long they are but at a guess 35mm? Yeah they would be about that. Has anyone had the nuts on these fail before? Prolly just idiots doing them up too "right" i'd say. I have destroyed heaps of these nuts Fine threads and rattle guns don't mix |
| Author: | Damo [ Sun Oct 05, 2008 9:48 pm ] |
TZAR wrote: Damo wrote: royce wrote: the thread IIRC is M12 FINE the studs in the axle, no idea how long they are but at a guess 35mm? Yeah they would be about that. Has anyone had the nuts on these fail before? Prolly just idiots doing them up too "right" i'd say. I have destroyed heaps of these nuts Fine threads and rattle guns don't mix Rattle guns are OK, it's usually the ape on the trigger that's the problem!!! Present company excepted of course I think i'll replace them with some course thread high tensile bolts. |
| Author: | royce [ Sun Oct 05, 2008 9:51 pm ] |
ive had plenty of nuts die, I think they are just too thin and they wear over time like all fasteners jsut get some generic nylocs, they fit fine and are a lot fatter, you could also turn wheel nuts around |
