Joined: Sun Jun 26, 2011 1:09 am Posts: 79 Location: Wyee, Nsw
Posted: Tue Mar 06, 2012 10:40 am
ok so after my alternator gave way i decided to do the alt upgrade on my coily.
After putting it in and wiring it up it wont start, i have reds and when i turn the key i get nothing. I have just checked the starter motor, its working fine.
Is this wiring related??
Any help is appreciated.
_________________ SJ80 Coily 2 inch body+40mm lift+31 inch M/T=:D
Posted: Tue Mar 06, 2012 11:07 am
turn the key and it doesnt turn over or wont fire? how did you check the starter motor?
did you disconnect the battery? if so check the terminals are back on tight and clean check you didnt bump the black/yellow signal wire on the starter too
Users browsing this forum: No registered users and 128 guests
