It is currently Wed Nov 04, 2026 1:33 pm
Post Posted: Thu Mar 08, 2012 3:19 pm
Discovered i have a problem with the drivers side lower control arm ball joint. Its gone dry and is squeeking when the steering turns. Does anyone know if they can be pulled out and replaced? I remember years ago that it could be done but now days every thing is a throw away part.
Suzistore want $360+ per side for a new arm with ball joint :shocked: :shocked: .
2nd hand ones are something like $100-$165 each depending on what wrecker you call.
I can order 2 replacement arms for $143 on ebay from the states but they want $200 for postage.....Way cheaper than i can get locally
If i can get them replaced ill do that but if not ill buy some new ones from ebay.
Post Posted: Thu Mar 08, 2012 4:07 pm
Mine are bolted in, maybe you could do something with.
or modify for early Vit ones?
No idea if arms would fit on a GV.
Post Posted: Thu Mar 08, 2012 4:26 pm
GV Calmini arms are probably the only solution
Vehicle: LWB Sierra & XL7
Post Posted: Thu Mar 08, 2012 4:59 pm
Looking at the GV Calmini control arms it looks as though they use the early model Vit's ball joints.
It probably won't hurt to see if you can buy just the control arms.
http://www.lowrangeoffroad.com/index.ph ... ystem.html
damn net connection, atari beat me to it.
'92 Vitara & Camper trailer
Vehicle: LJ80
Post Posted: Thu Mar 08, 2012 5:01 pm
in workshop manual
NOTE
suspension control arm and arm joint cannot be separated
if there is any damage to either parts
control arm must be replaced as a complete unit
bugger :evil:
Post Posted: Thu Mar 08, 2012 5:04 pm
33 minute intardnet delay... SUX2BU :D
Post Posted: Thu Mar 08, 2012 5:10 pm
Im yet to contact Calmini about just the arms. Will do that tomorrow.....maybe.
Post Posted: Thu Mar 08, 2012 5:12 pm
got sick of refreshing so had dinner. :lol:
Post Posted: Thu Mar 08, 2012 7:01 pm
Put vitara arms in?
Post Posted: Thu Mar 08, 2012 7:11 pm
Put vitara arms in?
I was thinking that too. Seeing as the front diff is pretty much interchangeable, maybe the arms are too
My Grand Vitara
Post Posted: Thu Mar 08, 2012 7:16 pm
the only thing i can think of is the swaybars are reverse mounted on the GV's
Post Posted: Fri Mar 09, 2012 10:37 am
Getting some Vitara arms this weekend to compare the difference. Hope its just the sway bar thats different........Will see.
Users browsing this forum: Google [Bot] and 90 guests
