It is currently Sun Nov 01, 2026 9:04 am
Vehicle: 08 jimny all stock atm
Post Posted: Fri Mar 09, 2012 5:16 pm
hey guys
im about to buy rims n tyres my tyre shop has recommended 15inch by 7 inch +10 offset
my car is a stock jimny 2008
is this the offset i want ?
cheers
Post Posted: Fri Mar 09, 2012 6:06 pm
How much lift are you planning on getting and what size tyre's?
Post Posted: Fri Mar 09, 2012 7:06 pm
40mm lift
215 75 15 tyres
Post Posted: Fri Mar 09, 2012 7:10 pm
7" rims are to wide for 215's. Not sure if you can get 6" wide rim's, but if you can look for a rim with a slightly negative off-set NOT positive. You want to increase you track width after lifting a 4wd :wink:
Post Posted: Fri Mar 09, 2012 7:22 pm
or just stay with ur factory rims, they work pretty good with 215's
Vehicle: '07 Auto Jim - Black
Post Posted: Fri Mar 09, 2012 9:42 pm
-VE offset will push the wheel out from the car giving a wider wheel track, +VE offset will bring them in reducing the wheel track.
-VE is the one that you are after, particularly if you are lifting the car. -13 is a pretty common offset to works well on the Jimny. But as monley said, 7" is too wide so stick with the stock unless your changing it for looks
Post Posted: Fri Mar 09, 2012 9:52 pm
sounds like ill stick with the factory alloys
cheers
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Sat Mar 10, 2012 8:54 am
yep thats the way to go with 215s.
this is 215s on stock rims and no lift.
Post Posted: Sat Mar 10, 2012 3:54 pm
I have 215d on 7s. works ok.
also u need atleast -10 to clear steering arms on a jimny with 7s
Post Posted: Sat Mar 10, 2012 6:44 pm
Bill shit. I was driving a jimny today with 15x7 0 off set and they don't hit.
Post Posted: Sat Mar 10, 2012 7:31 pm
i will be going some 31x10.5 on some 15x8 -23 offset. got a 3" lift and have defender extended arches. to fit them in, with extensive original arch cutting.
Post Posted: Sat Mar 10, 2012 9:05 pm
mine are -10 and they clear buy around 3mm.
Vehicle: Suzuki Jimny 2009
Post Posted: Sun Mar 11, 2012 8:47 pm
I have 15 x 6 with close to 0 offset (+3 I think) and 217/75's. No clashed with steering and no scrubbing.
Post Posted: Sun Mar 11, 2012 9:28 pm
Don't forget those rims you have are a different shape at the back compared to a steel rim Phil. Let's not confuse people here with different fact's.... :)
Post Posted: Mon Mar 12, 2012 7:06 pm
My rims are 7" with -5 offset (roughly). I think they fit perfectly for up to 235/75R15. They don't cause any clashing.
Also don't stick out of the flares which is good when the law comes up behind you ;)
They do bring the tyres in line with the outer face of the flare.
Users browsing this forum: No registered users and 324 guests
