http://auszookers.com/forum/
mods help for coily
http://auszookers.com/forum/viewtopic.php?f=5&t=31062
Author:  fully sick coily [ Fri Mar 09, 2012 7:19 pm ]
Post subject:  mods help for coily
hi everyone,
i just bought a 1997 coily and was wondering if there is any thing i should brace/replace :?
on it befor i go wheeling so far i have:
30"x9.5 maxxis buckshots on sunraisia rims (15x8) :D
alloy roll and bull bar
also is there any mods i can do at all
any help is apreciated
Author:  Rusho [ Fri Mar 09, 2012 7:24 pm ]
Post subject:  Re: mods help for coily
Budget?? Suspension, swap bar removal, t'fer gears
Author:  fully sick coily [ Fri Mar 09, 2012 7:31 pm ]
im limited to first year aprennis wages
hav already removed swaybar
i hav been told i need to brace controll arm mounts?
Author:  Rusho [ Fri Mar 09, 2012 7:35 pm ]
Brace every mount on the diffs, including panhard.
Author:  fully sick coily [ Fri Mar 09, 2012 7:47 pm ]
would you happen to have any pics as i am new to this?
Author:  want33s [ Fri Mar 09, 2012 8:01 pm ]
Brace all the radius arm mounts on both the diffs.
Reinforce the shock towers.
Swap in a gear driven transfer.
Buy a leafy.
Author:  fully sick coily [ Fri Mar 09, 2012 8:27 pm ]
how do i Reinforce the shock towers.
Author:  Rusho [ Fri Mar 09, 2012 9:03 pm ]
Weld a 2 or 3 mm washer over the top of it. Big enough to cover the top of the strut mount and with an appropriate sized hole for the strut thread
Author:  Fatzook [ Fri Mar 09, 2012 9:21 pm ]
Bring it to my place and I'll do it for you. Done plenty of the shitboxes, so whats one more :thefinger:
Costya a 6pack of bundy. (Thats cheap!) :wink:
Author:  Fatzook [ Fri Mar 09, 2012 9:23 pm ]
On the topic,
You can do things like diff breathers, headlight upgrade, LED interior light, and reverse light (camp light), general maintenence.... Heaps of low budget stuff you can do.
Author:  Rusho [ Fri Mar 09, 2012 9:36 pm ]
This is heaps easier than my idea pompoms
Author:  fully sick coily [ Sat Mar 10, 2012 5:52 am ]
thanks so much guys i got a LED interior light (lights) it lights up my whole car 8)
and ill start makin a reverse light today :? as for breathers what is the best hose to use?
also fatzook any chance you could brace my difs aswell? :roll:
Author:  Rusho [ Sat Mar 10, 2012 5:58 am ]
It's his favourite job... pompoms
Hose for breathers. I used garden hose, 95% of the people on here will disagree. Mainly because it isn't oil resistant :roll: I have had garden hose on my car for 2 years and it has worked a treat :peaceout:
Author:  fully sick coily [ Sat Mar 10, 2012 6:27 am ]
awsom mate do you hav any pics of your diffs?
just so i can see what you mean
Author:  Rusho [ Sat Mar 10, 2012 6:47 am ]
My front diff is from a leaf sprung Sierra. The rear is standard coily...unbraced :( The mounts just get swapped for a thicker material 3 or 5mm
Author:  fully sick coily [ Sat Mar 10, 2012 6:52 am ]
My front diff is from a leaf sprung Sierra. The rear is standard coily...unbraced The mounts just get swapped for a thicker material 3 or 5mm
why a leafy front diff and does the rear need bracing?
Author:  Rusho [ Sat Mar 10, 2012 6:55 am ]
Because I wanted to piss off the struts and radius arms, the other bonus is I now have cromo cv's/axels and a lokka Armsup
Author:  fully sick coily [ Sat Mar 10, 2012 7:10 am ]
Author:  Rusho [ Sat Mar 10, 2012 8:08 am ]
Only ever had a problem with my rear diff. I think this is because the rear of a coily works a lot better than the front...suspension wise, therefore it creates a lot more stress on the mounting points. JMO though :wink:
Author:  Fatzook [ Sat Mar 10, 2012 12:19 pm ]
Not on 1st year apprentice wages :wink:
You're welcome to swing by, and I can talk you through what you do and don't need, and what you can get away with short term.
Author:  fully sick coily [ Sat Mar 10, 2012 12:52 pm ]
how much would you charg for the front diff and strut reinforcement
Author:  fully sick coily [ Sat Mar 10, 2012 7:39 pm ]
ok so i made up a reverse light (150w) 8)
polished my bull/roll bar :blingbling:
attempted fender flares (epic fail :oops: )
ripped my soft top :x
and installed 2 150w spotties :D
what other easy mods is there?
Author:  redrocketsj50 [ Sun Mar 11, 2012 7:41 pm ]
Auszookers sticker
Author:  fully sick coily [ Mon Mar 12, 2012 4:19 am ]
on its way ;)
