You can 1.6 as its cheap and according to about a million people is so much more power it makes you smile right away. Then work our if you still need more power and can afford to do it properly.
Gearing is your friend too. Monkey mentions tires above, basically if you run bigger tires you need bigger ratios. 24% in the jimny box or lots of options with a sierra case are easy starting points. blowing up Jimny gearboxes is easy depending on model and power, if you turbo you will probably want to stick in an aw4.
Users browsing this forum: No registered users and 223 guests
